Highest MPG while loaded
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 05 FreightShaker, Jan 30, 2014.
Thread Status:
Not open for further replies.
  1. 05 FreightShaker
    05 FreightShaker Light Load Member
    265
    30
    Jan 20, 2013
    Houston
    I want to know the highest and lowest mpg anyone has seen on their trucks and if loaded or not. :yes2557:
  3. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    9.2 mpg on 2014 prostar with 20000 lb reefer loaded.
    05 FreightShaker Thanks this.
  4. 05 FreightShaker
    265
    30
    Jan 20, 2013
    Houston
    Is it all stock? Any pics? I get around 8.5ish with 45k and 7.6ish in the hills. And then maybe someone else can chime in on the "trailer tails" and side fairings on the dry vans if they actually help or just a useless addon.
  5. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    Yep, stock truck with Michelin x-one. the trailer had smarttruck undertray ut6, meritor inflation system, and x-one super single
  6. 05 FreightShaker
    265
    30
    Jan 20, 2013
    Houston
    What ratio are your rear ends? Im impressed to see a newer model truck get good mileage. What engine are you running?
  7. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    I know the engine is Maxxforce 13 def. It will keep running on 10th gear when climbing on mountains. The truck belongs to hirschbach. The diff labels weren't on the truck for some reason, but I'm sure it was somewhere 3.08 or less. It ran stronger than the 2012 Cascadia with 455 hp/ 1550 lb ft and 2.53 gear ratio.
  8. 05 FreightShaker
    265
    30
    Jan 20, 2013
    Houston
    Ah ok no wonder...its the gearing and i guess you run about 65 or under?
  9. 05 FreightShaker
    265
    30
    Jan 20, 2013
    Houston
    And the maxxforce 13 is essentially a cat c13
  10. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    yeah, because it has a twin turbo setup just like the acert engines. Doesn't has strong jakes on it.
  11. cuzzin it
    cuzzin it Road Train Member
    3,639
    11,647
    Jan 19, 2008
    Berea, KY
    9 going through nebraska with 44K of spuds with a polite tailwind :biggrin_25522:
  • Thread Status:
