Holset turbo on a 6NZ C15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Nevs, Feb 6, 2011.
  1. Nevs
    Nevs Light Load Member
    295
    107
    Dec 25, 2010
    flyover country (Iowa)
    Is anyone running this combination? Good, bad or ??? I'm looking to upgrade my turbocharger, I'm leaning towards the Bully Dog because it's a straight bolt on, but I've got a couple of friends who are running the Holset combo and swear by it. Looking for thoughts from others. Let me know your thoughts, pro and con.
  3. durallymax
    durallymax Medium Load Member
    318
    97
    Jan 30, 2011
    as for big rigs, dont know,m but coming from the Dmax world, Bully Dog=No no.
  4. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    I've seen too many trucks show up at dyno cntests with Holset turbos on them that did not build good power for the parts on the engine. Power is usually down 100-125 hp to the tires. The reason for this is the exhaust housing is very restrictive and creates high drive pressure versus boost pressure. The engine will build 55 psi of boost but have 65-70 psi of exhaust back pressure in the exhaust manifold before the turbo. If you increase the exhaust housing size to get it to flow properly then they get very sluggish at low-mid engine RPM and build high EGT's whie cruising.
  5. Jim Dandy
    Jim Dandy Bobtail Member
    Illinois
    Mr. Haney how can I get in touch with you.
  6. Nevs
    295
    107
    Dec 25, 2010
    Mr. Haney, any experience with the Bully Dog turbo?
  7. Mr. Haney
    2,693
    2,040
    Dec 17, 2008
    Yes, I know how to build a Bully Dog Stage 1 turbo for the CAT application.
    It is a very good turbo up to 700-725 hp. Very fast response with a newer design ETT compressor wheel. Balance between the exhaust back pressure and boost psi is 1:1 through out the complete RPM range.
    The problem is getting the components to build one. The parts aren't readily available depending on the distributors inventory at times. I'd have to make some phone calls to see if the parts are available and prices if you're interested in one.
  8. Donk
    Donk Have a Cup Of Concrete
    1,643
    9,232
    Apr 27, 2008
    is this the HX60 non WG as used on the n-14 525, the hx60 non wg with small exh hsg used on early signatures or the later HX60WG used on later signatures?
  9. Mr. Haney
    2,693
    2,040
    Dec 17, 2008
    Holset part number is 3801919. I believe it is off the N-14 460-525 hp range, it is a non-wastegated 26 CM exhaust housing.
    Donk Thanks this.
  10. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    Any thing can go wrong with any manufactor,but I have seen Holsets come apart on the air side and literally saw the air cover off and leave it dangling by the innercooler piping...so I tend to stick with other manufactors. The Turbos Mr. Haney is speaking of work well.
  11. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    I believe everyone of the pictures I have seen of a conversion is a HT60, personally I think the HX60 would be a better option than what they sell, but it still doesn't match the performance of the Borg-Warner turbos.
    The thing I always look at with holset is that they haven't released a new medium or large frame turbo in the last 10 or so years it seems like, there stuff works, but Garrett and Borg-Warner are leaving them in the dust with their newer products.
