Home terminal question and other questions
Discussion in 'Knight' started by sharp.dressed.man, Apr 21, 2013.
  1. sharp.dressed.man
    sharp.dressed.man Heavy Load Member
    701
    507
    Dec 10, 2011
    IL
    Would I have a choice of home terminals or will I have one assigned? I am looking at doing regional dry van unless I could run intermodal. I am in St. Louis, MO.
    My legal residence is in St. Louis, MO, but I would like to take my hometime at various locations in IL on a regular basis. Would this be a problem at Knight?
    What is the current idle policy at Knight?
    Thank you in advance for taking the time to answer my questions.
  3. dschmidt201
    dschmidt201 Light Load Member
    289
    109
    Jan 6, 2012
    Chicago
    Knight doesn't care what you want to do your gunna find that out real quick specially when your checks are messed up
  4. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    Most times trucking companies base your home terminal by how far you live to the closest terminal. In other words they ll assign you a terminal.
  5. OverDrive
    OverDrive "A Watchman on the Walls"
    Generally, "Yes." But I've seen drivers 'pull strings,' but they have to regularly get to that terminal for maint/safety training, etc.
    I've seen Fontana drivers (nobody likes Fontana!) xfer to Tulare (a fairly good terminal as far as Knight goes)
  6. mitrucker
    mitrucker Road Train Member
    5,266
    9,342
    Dec 15, 2010
    Lapeer, MI
    You would most likely have one assigned. Hometime in other areas I have no experience with, but I don't see where that would be an issue. The idle policy is....is its between 32 and 70 your truck won't idle. If your idle percentage goes over ten percent you lose 2 mph (65 to 63).
  7. drozzer69
    drozzer69 Road Train Member
    1,206
    1,143
    Oct 20, 2012
    Spring, TX
    More than likely you will be out of Kansas City terminal. I am sure that if you talk with your DM when you get in, he could probably arrange that you can take time in Illinois. The termianl there is in Joliet. Idle policy is what is stated above. This is the defining time of getting hired on. Drivers that sign on in summer will mostly have high idle time because of the obvious reasons. The only saving grace would be if you use idleair at some of the truck stops. Over all Knight is a ok company. I have been with them for 3 1/2 years. Just run the loads, be ontime, don't have accidents and you will do fine. Hope this helps in your decision.
