Hooking to a trailer
Discussion in 'Questions From New Drivers' started by Penumbra, Nov 7, 2019.
  1. Penumbra
    Penumbra Medium Load Member
    305
    528
    Jul 29, 2019
    So, I’ve got a bad habit and I can’t figure out how to fix it.
    while I’m backing into a trailer to hook up, I never hit it flush. The trailer always shifts sidewise a couple inches before it slides into the fifth wheel.
    Is this normal? Anything I can do to fix it?
  3. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    I do that about 50 times a night lol so I would like to hear about this also.
  4. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,080
    Sep 24, 2019
    Raleigh, NC
    Watch your drives as they start to go under the trailer. Mirrors not perfectly adjusted can throw you off.
  5. Mid-May Trucker
    Mid-May Trucker Road Train Member
    1,118
    2,079
    Oct 23, 2018
  6. Penumbra
    305
    528
    Jul 29, 2019
    I’ve been doing that, and from my mirror AND looking over my shoulder it certainly looks like Iined up properly, but alas it still slides a bit to the side.
    normally, no big deal, as soft as I back up it doesn’t do any damage.
    However, right now I’m sitting in front of a trailer that’s jacked up a good 4-6 inches on wood blocks...sliding the trailer seems like a bad idea lol
  7. Mike250rs
    881
    7,080
    Sep 24, 2019
    Raleigh, NC
    I went by amount of tire as it went under. The more even, the more better and straighter it seemed.
    buddyd157 Thanks this.
  8. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    Many times I haven’t backed perfectly straight and the trailer corrects it. But it’s by inches. I never miss the Kingpin or make the legs move more than maybe a centimeter. Just go in slow and look at both mirrors making sure both wheels are more or less symmetrical under that trailer. A crooked mirror can set you off some.
    FlaSwampRat and tscottme Thank this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    I make sure the 5th wheel plate is set down so it's presenting to the trailer at a angle for it to "Hop up" onto and "CLANK!" the plate horizonal while it goes into the jaws doing what it needs to do to make the final hook.
    I don't worry about that trailer too much. As long the jaws shut and she passes the tug test.
  10. Tx Countryboy
    Tx Countryboy Road Train Member
    1,968
    4,437
    Sep 18, 2019
    If it's loaded heavy& you are at too much of an angle it could mess up landing gear.
    Bean Jr. and FlaSwampRat Thank this.
  11. buddyd157
    buddyd157 Road Train Member
    13,576
    34,885
    May 25, 2017
    under a shade tree
    before you fully back under any trailer, line up your tires to the trailer edges. if you're (say) 2 inches off, pull up, straighten out, do it again. repeated incorrect lining up with the trailer will in time, bend the landing gear.
