Hooking up connex-3300hp
Discussion in 'CB Radio Forum' started by Snapshot1673, Jul 24, 2016.
  1. Snapshot1673
    Snapshot1673 Bobtail Member
    Can I hook up a 3300 HP to the wires in the radio compartment in my semi ?Radio has been peeked and tuned. Thanks, snapshot.
  3. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Most semi's have a large enough fuse to handle your radio, but it is always suggested to run your own wires direct to battery.
    Ougigoug Thanks this.
  4. rabbiporkchop
    9,677
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    Something that small I see no reason why not.
  5. Jesus is the only way
    Jesus is the only way Bobtail Member
    36
    23
    Jan 6, 2014
    Coeburn V.A.
    Yes you can and no you wont have one single problem with it. But....if you end up getting electric noise from you alternator in the receive of your radio... The easy way to fix that is to clean a spot on your seat frame down to bare metal and connect your black wire there. I've done this more times than I can count and it works just fine.
    The only problem you may run into is blowing the fuse for that power source but tha's at simple to fix by installing a larger fuse.
    rabbiporkchop Thanks this.
