hopper bottom rates
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by cmbks21, Jun 15, 2015.
  1. cmbks21
    cmbks21 Medium Load Member
    327
    94
    Nov 9, 2013
    You call on a load and they say we got it at 90cents a bushel, that means the truck gets paid that right?
  3. Army91W
    Army91W Heavy Load Member
    751
    733
    Nov 3, 2006
    San Antonio, TX
    Yeah, corn is 56lbs per bushel you can haul 49,000. (For example)
    49,000lbs divided by 56lbs is 875 bushels times .90 equals $787.50.
    cmbks21 Thanks this.
  4. cmbks21
    327
    94
    Nov 9, 2013
    Thanks, I was just curious if that's how it worked, I'm new to the hopper world, little different than oil
  5. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    Ton bushel all pays by weight. Don't get hung up on that 56lbs/bu on corn. I've seen 54, 56, etc. Keep your scale tickets they'll give you the test weight moisture etc. More bushel more money but you'll be a DOT magnet and you'll also be time stamped everywhere you go keep that in mind the log needs to match the stamp carry a copier and white out when in doubt.
    blade Thanks this.
  6. damil
    damil Light Load Member
    171
    247
    Sep 23, 2012
