Horizontal muffler can I just straight pipe it and pass dot?
Discussion in 'Ask An Owner Operator' started by Ruckie, Aug 22, 2016.
  1. Ruckie
    Ruckie Road Train Member
    1,485
    1,029
    Nov 12, 2011
    Bloom field,nj
    Well this is my issue my shop quote me at 1500 dollars for parts and labor for a horizontal muffler and the split for a 06 century class with dual exhaust which I think it's too expensive, I'm trying to see if I can buy an aftermarket horizontal muffler and just turn it into a grass burner and save money by not buying flex pipes every year. Now can I just straight pipe the exhaust or will that make me fail the emissions test?
  3. rollin coal
    rollin coal Road Train Member
    13,269
    26,726
    Mar 29, 2008
    TN
    Yeah you could make it a grass burner with a muffler and be just fine. Or quit cheaping out on the flex pipe you're buying. Pay a few dollars extra for stainless flex and your annual rot problem will disappear.
  4. AModelCat
    158,403
    Straight piping I don't believe is considered tampering with emissions equipment so long as they aren't catalytic mufflers that you're removing. They can possibly fail your truck for not having a muffler though. Some places consider the turbo as a sound dampning device and others require a muffler. Your best bet would be to install a short, horizontal muffler or resonator under the cab and to make sure that the exhaust is not exiting under the cab. A carbon monoxide alarm would be handy as well since the exhaust has a greater chance of entering the cab as well.
  5. Ruthless
    Ruthless Road Train Member
    8,932
    87,847
    Aug 28, 2010
    The City.
    @Ruckie you still in nj?
    @NorthernMechanic nj does visual opacity tests as well as sniffer tests.
    Only place I ever got checked. Visual only and I only blipped it to 1200 bc I claimed I had a muffler and I don't think that would have been believable if I kicked it hard..
    Idk how much a muffler really catches smoke, or affects a test like that- but you tell an inspector you got straights...seem like an easy way to earn a fine to me.....
  6. Ruckie
    1,485
    1,029
    Nov 12, 2011
    Bloom field,nj
    yes I'm still in nj
    Big_D409 and Ruthless Thank this.
