Horrible Vibration (Pounding) in Rear End, 1991 F-liner FLD-120
Discussion in 'Freightliner Forum' started by jerfle, Nov 25, 2014.
  1. jerfle
    jerfle Bobtail Member
    Recently started feeling a pounding while rolling down the interstate empty. Thought it was just mud on the inside of my duals since i drive a lot on dirt roads....not it. Seems to come and go and occurs around speeds of 55-70 mph. Thought i might have a bad cap so put new caps on...again didn't work. Put Centramatics in between by drivers and still hasn't helped. Was told to check the aluminum blocks between my springs and the axels for cracks and they are in good shape. Anyone have any suggestions?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    bent rim maybe??
    jerfle Thanks this.
  4. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Get on a cell phone and a buddy riding next to you on the right then the left and try to determine where it's coming from. Might be able to narrow down your search. This is a real tough problem to find!!! I know!
    Ride height
    Bad wheel bearing
    Bad universal joint. If you recently had your rear end hopping up and down trying to get out of sand it can damage them real quick
    Drive shaft out of balance. Some have weights welded to them and they can come off
    jerfle Thanks this.
  5. zinita17601
    zinita17601 Road Train Member
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    Had the same truck same problem,vibrate at only certain speed only when empty,after taking it to three shops and dropping the drive shaft twice took it to a drive shaft shop,drive shaft wasnt balanced one yolk was missing the lip that keeps the u joint in place.problem solved.i advise you to fix it asap cause the vibration will brake the driveshaft carrier.hope this helps
    jerfle Thanks this.
  6. jerfle
    Thank you for the suggestions! You mention ride height, I looked at my air control valve and noticed the lever isn't level with the ground but when you move it up/down, it still allows air in and out. Is this a problem?
    Also have changed 2 U-joints, carrier bearing, gone through the rear end from the wheel bearings out to the brake drums.
    Im also thinking either a rim or a drive shaft!
  7. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    You can adjust the ride height like 1/2" and take it for a ride then try the other direction.
  8. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    I meant a 1/2" on the level rod not the truck height.
    lovesthedrive Thanks this.
  9. Joetro
    Joetro Road Train Member
    2,416
    2,409
    Aug 23, 2008
    Post Falls, ID
    The title opens too many doors for jokes. I know this doesn't help, but...
  10. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    LMAO...Ya know. I was going to say something but I decided not to. Something about prison trucking or like that
    Joetro Thanks this.
  11. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Went to dealer once and said my rear end was leaking. Everyone lost it
    lovesthedrive and Joetro Thank this.
