Horton DM 2 speed fan drive
Discussion in 'Peterbilt Forum' started by pupeperson, Sep 25, 2013.
  1. pupeperson
    pupeperson Light Load Member
    216
    203
    Jun 9, 2013
    Anyone on here have experience with this unit? It's an "eddy current" drive on low speed and then it locks up like a regular fan clutch when needed for additional cooling. My question is: Does this fan drive ever shut completely off when not needed for cooling the engine or A/C system? Or, when the engine is running does it operate continuously on the eddy drive, locking into high speed only when needed?
  3. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    You may have the wrong solinoid
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    They never shut off fully, their is nothing to deactivate the magnets.
    pupeperson Thanks this.
  5. pupeperson
    216
    203
    Jun 9, 2013
    Thanks. I thought perhaps the magnets were electromagnets that relied on a signal from the ecm to activate them. Makes me wonder why they are not.... Back in the late 80's there were fan clutches available that did use electromagnets. I thought they were great -- nothing to wear out or slip like a clutch disk. Cummins bought 'em out and they've not been seen since.
  6. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Be careful if you rebuild that clutch, those magnets are pretty stout. Gave me a heck of a blood blister when they snapped together with my finger between them. Keep them away from each other. I've never seen a clutchless one that relied totally on magnets to turn the fan. I've seen the Warner electric hubs, but they were like an A/C compressor clutch, an electric magnet engaged the clutch. I've only seen them on medium duty engines.
  7. pupeperson
    216
    203
    Jun 9, 2013
    It was a Facet brand fan drive. There was no mechanical connection other than the bearings on a common shaft between the fan and the hub assembly. There was an electromagnet that when engaged caused the fan to spin at the speed of the shaft on which it was mounted. Engagement was gentle in comparison with a clutched drive like a Horton, with no violent torque spikes. I had several of them on early Detroit Series 60's in Freightliners. They weren't modulated to operate at varying speeds, just off and on. I was really happy with them. No failures at all.
