ok, take the 60/7 as an example. is the 60 max "on duty time" or "driving time"? so once i hit 60 hours "on duty" is my week done and need a reset? thanks
HOS question
Discussion in 'Questions From New Drivers' started by p47, Dec 29, 2014.
It is a combination of both, kind of. After 60 hrs, you can't drive until you either get a reset, or you get some hrs back via recapping. HOWEVER...... you CAN go past 60 hrs as long as it is on duty NOT driving. See what I mean by "kind of"?
p47 Thanks this. -
so once i hit 60 hrs. driving and on duty combined, i have to stop driving, bit i can keep working as on duty.do i log that time as on duty. seems my log book would be in violation.
the govt doesnt care about you working, onduty
they only care about you driving a CMV after your 60hrs
you can work 100hrs straight, but you cannot drive after you have worked 60hrsp47 Thanks this. -
ok, i get it. sorry for being dence.
No need to be sorry or feel like your being dense. HOS can be pretty confusing when your 1st starting out. Most starter companies will have elogs, and that will help you from making any major mistakes.
p47 Thanks this. -
good morning everybody. please explain the recap hrs. are they just the driving hrs that you get back. if i don't get this figured out I'll think about it all day, and I've got school to concentrate on. thanks again
They are not just driving hours. They are a combination of both "on duty" and "driving" hours. Example: if you drove for 8 hours and was on duty for 2 hours you have used 10 hours out of your 60.
Recap is simple, grab your log book. Count current day as 1 then count back 8 days. The hours you used on that 8th day can be added to your current HOS total.
Edit: my mistake. You are on 60/7 so your recap would be current day plus last 7 days. Hours used on the 7th day can be added to your current HOS total.p47 Thanks this.
