Hot box suitable to run with a stryker SR 955
Discussion in 'CB Radio Forum' started by Side pipes, Nov 27, 2022.
  1. Side pipes
    Side pipes Light Load Member
    93
    72
    Nov 27, 2022
    Ireland
    I have a stryker SR 955 the first edition abs if any one is using the Newer version what’s the difference as they look
    Identical , what are a good HD 4 pill Amp I was looking at a Texas star but don’t like the way the fins are on the bottom
    Of the Amp .
  3. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Dang thing runs 70 watts with no amp, right?
  4. Side pipes
    93
    72
    Nov 27, 2022
    Ireland
    Right but when the skip starts rolling in to many heavy hitters out there little mud duck station gets covered up
  5. Tall Mike
    Tall Mike Road Train Member
    7,492
    35,445
    Aug 20, 2014
    The Hammer Lane
    I would strongly recommend X Force (gray label) or Magna Force that were built by Carl before he sold out if you can find one used. I've run both and had good luck with both. If I needed a new amp I'd go with Carl Built, he is back building amps. I've personally talked to Carl on the phone he is a good dude and really sharp he knows his stuff. If I found a used amp built by Carl I'd nicely ask him if he'd look it over.
    Carl Built Amplifiers
    Another good choice would be BBI based on everything I've heard. If I needed an amp repaired that wasn't built by Carl, BBI would get the job.
    BBI Amps Home
    Side pipes Thanks this.
