Hot Shotter
Discussion in 'Expediter and Hot Shot Trucking Forum' started by alex94, Apr 21, 2009.
  1. alex94
    alex94 Light Load Member
    286
    78
    Dec 6, 2008
    good ol CG
    not trying to sound stupid but what is a "hot shotter"? i have been reading around the forums and have seen this in a few places(o/o and expediters mainly.) thanks eeryone!
  3. ziggystyles
    ziggystyles Road Train Member
    I could be wrong...but hot shots are usually people in pickup trucks, like Diesel Fords or Chevys...etc. Hauling campers, and other loads that need to be hauled, but don't need a Big Rig to do so.
  4. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    This has been debated but most define hotshot work as a kind of flatbed expedite moving time sensitive , high paying loads . O/O's they call themselves hotshotters do not consider LTL and RV haulers hotshotters . But if hotshotters did hotshot work exclusively they'd starve . I know a hotshotter that recently started hauling cars to keep his trucks moving . He still has to get a decent rate though .
    At one time expedite work was called hotshot and sometimes is still referred to as that .
  5. alex94
    286
    78
    Dec 6, 2008
    good ol CG
    thanks for the replies. generally, what kind of cargo do they pull? and where/how do they get their loads? from load boards? thanks.
  6. fisher guy
    fisher guy Road Train Member
    1,993
    1,060
    Mar 22, 2009
    Ocala Florida
    there for runnin time sesitive parts and supplies for the oil firelds but they also run flatbed loads like pipe. usually through broker or there own connections
  7. RickG
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    There is one O/O with a stepdeck leased to FedEx Custom Critical . He does a lot of aviation work . I read in Landstar's Success magazines about a couple of interesting loads . One was for a generator for a cruise ship in Alaska . It was trucked from Denver to Atlanta then flown to Alaska then had to be put on a barge because the cruise line didn't want it loaded from the dock side where the passengers could see it .Another was a turbine for a helicopter in Alaska .
    But as I said earlier , hotshotters have to haul some regular freight to survive . I know one that gets loads from a manufacturer of pole barns . Some orders are too heavy to get on one flatbed to he gets the balance of the order . He has hauled rebar for construction projects . If you see the goosenecks on the road you'll see what they are hauling .
