Hours of Service: Can I Go Over 14 Hours in the Company Yard?
Discussion in 'Trucking Industry Regulations' started by trucker3573, Dec 3, 2011.
  1. trucker3573
    trucker3573 Light Load Member
    97
    21
    Nov 1, 2009
    Here is the scenario.....I work in the LTL industry and do a short run every night. I usually work 11 to 11.5 hours a night with driving, dock working and breaking and hooking sets, however this week was crazy busy and one morning I literally pulled into our yard at my 14th hour. I was concerned that I could not show dropping out my set and fueling the truck (both compensated tasks) as it would put me over my 14 hours. I had several people tell me that I can log over 14 on the on duty not driving line as long as i am done driving given that:
    1). Do not drive again until 10 hr break is taken.
    2). Do not work over 70 hrs a week.
    This just goes against everything i thought I knew, I thought when your 14 hr clock was up it was up. Is this true....can I go over 14 once I am in the yard and will not drive again before a 10 hr break......wether it be dropping trailers or even working the dock. Would really be great if a DOT officer could answer this. Thank you in advance all.
    scottied67 Thanks this.
  3. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    395.3 FMCSR
    (a) ... nor shall any such driver drive a property-carrying commercial motor vehicle:
    (1) More than 11 cumulative hours following 10 consecutive hours off-duty;
    (2) For any period after the end of the 14th hour after coming on duty following 10 consecutive hours off duty...
    (b) ...nor shall any driver drive a property-carrying commercial motor vehicle... for any period after—
    (2) Having been on duty 70 hours in any period of 8 consecutive days ...
    Re-stating the rule:
    - You may not DRIVE more than 11 hrs after 10 hrs off-duty
    - You may not DRIVE after the 14th hr after coming on-duty following
    10 hrs off-duty
    - You may not DRIVE after being on-duty more than 70 hrs in 8 days
    You can work or be on-duty 24/7, the DOT (Department of Transportation) does not care. They only regulate and limit the DRIVING of CMV's.
    Once you are over the hours limits you can WORK all you want to. You can work over 70 hrs in a week. You just can't DRIVE (even on private property - yard) until you get another 10/34 hrs off-duty.
  4. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    Well I'm not an LEO...in fact far from it but what your askin is correct. When you drove in your yard you can go on duty not driving and still go over your 14 hours and not be in violation but you must take a full 10 hour brake before you can drive again.
    Simple rule; you got 14 hours to drive 11, you cant drive past the 14 hour clock, but you can be on duty not driving past the 14.
    48Packard Thanks this.
  5. trucker3573
    97
    21
    Nov 1, 2009
    AHH ok my interpretation was wrong....good deal just didn't want to be checked later in the week and get a ticket. Thank you all.
  6. Scalemaster
    808
    1,717
    Mar 13, 2011
    Midwest
    Minor correction to your statement...
    When you drive a CMV ANYWHERE, even on private property, it is DRIVING time.
    395.2 Interpretaton Question 9: A driver drives on streets and highways during the week and jockeys Commercial Motor Vehicles in the yard (private property) on weekends. How is the yard time to be recorded?
    Guidance: On-duty (driving).
    keepntruckin Thanks this.
  7. Meltom
    Meltom Road Train Member
    5,423
    3,019
    Jan 24, 2011
    Just gonna get nit-picky here, this is just guidance of an interpretation question. So much like personal conveyance it can be interpreted many ways. So really it should say something like it SHOULD BE driving time.
  8. FwL
    FwL Medium Load Member
    438
    331
    Aug 30, 2011
    Sandpoint, ID
    This is way too common.
    I've probably debated five different people on this since I started school. Even my trainer is convinced he can't do any work past his 14. I've tried to convince him otherwise, but what do I know?
    The Idaho and Washington CDL manuals are no help either:
    Q. How many hours may you legally drive?
    Expected answer: 11
    Q. How many hours may you legally be on duty?
    Expected answer: 14
  9. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    Yes it is
    He is in error. One way to explain it to someone is to have them read part 393.3 (Or all of 395) and have them show you where it states you cannot work (On duty not driving) past 14 hrs. Scalemaster already quoted the part, which states that one cannot DRIVE past the 14th hr.
    CDL manuals generally do not address HOS
    As written the "Expected answer" is incorrect. You can be on duty as Scalemaster stated 24/7 or for that matter you can be on duty from now until you have dirt thrown on your face. You just can't DRIVE past the 14th.
  10. ITS62
    ITS62 Light Load Member
    164
    69
    Apr 29, 2011
    Gilroy, CA
    There shouldn't be any debate on this one...FMCSA regulates DRIVING hours, not WORKING hours (on duty)...
    per the FMCSA FAQ page:
    D-1. May a driver be on duty for more than 14 consecutive hours?
    Yes. A driver may remain on duty for more than 14 hours; however, the driver of a property-carrying CMV cannot drive after the 14th hour after coming on duty. Also, the additional on-duty time will be counted toward the 60/70-hour on-duty limit.
    http://www.fmcsa.dot.gov/rules-regulations/truck/driver/hos/hos-faqs.asp#_Toc111021248
    One of my newer employees rolled into the yard once right at then end of his 14 hour window and said "can't legally touch the truck again, I am outta hours, see ya"...WRONG! You can't DRIVE anymore until you have had a 10 hour off duty break, but you can work another 24 hours straight if needed as long as you don't drive a CMV. Back to work sucka!
    Everett and scottied67 Thank this.
  11. Scalemaster
    808
    1,717
    Mar 13, 2011
    Midwest
    FMCSA Regulatory Guidance, or Interpretations, have the weight of law.
    They are clarifications of regulation, and are based on case law.
    keepntruckin and nicholas_jordan Thank this.
