I have 2 50 gallon tanks. I have been filling them up when the light turns red and have even ran it longer I have a spare tank in my toolbox in case it runs out completely trying to know how far the truck can run before it’s complete out. Every time I fill them back up I pump about 85-88 gallons . Being a new O/O It’s just some information I’d really like to know about my truck . Could it be that it really only fits 90-95 gallons?
How accurate are the gallons in fuel tanks ?
Discussion in 'Ask An Owner Operator' started by b947, Dec 19, 2019.
Page 1 of 3
The gauge is weighted so you don't run out of fuel.
Not real smart to run your tanks low..but just keep running them to empty and let us know..PE_T, Crude Truckin', bzinger and 3 others Thank this. -
The gallons marked on the tanks are 95% of the actual tank capacity. I have 2 100 gallon tanks on my pete and have ran it down to where Ive put 195 gallons in but I also fill my tanks to where its just about to run out of the filler hole. Depending on the fuel blend, pump rate, and style of nozzle I can normally get 5-10 gallons more into the tank after the nozzle clicks off.
I’d say your running them to about as empty as I’d wanna run them on a normal basis.Upinsmoke Thanks this. -
The tanks are turned alittle, and u can't fill to top, yes maybe 10 gallons short on each so figure 40 gal times fuel mileage,,,,, figure 5
With two 70 gallon tanks, I pushed ~100 miles past the light coming on, and topping off only put in like 115 gallons or something. The next time I tried it I wasn't as lucky. I don't push it below 1/4 tank anymore.
So the light comes on, how many gal r still n tank.......... The manufacturer sets it at a certain , same n your car,...... DON'T!!!!!! DON'T!!!!! EVER go by your Gage, use a stick of some kind or just fill up at a certain mileage
Thank youGuys for the response. I’ve only ran it low two times which is why I was wondering. But I usually fill up at a quarter tank left as well. Plus the miles I have driven per trip and trip fuel economy where not adding up . And one of the times I ran low diesel was 4.32 in a small city up in the hills and it was 3.29 about 60 miles down .
Upinsmoke and shatteredsquare Thank this. -
tscottme Thanks this.
Those are small tanks and your fuel mileage seems pretty bad. Just curious, what are you driving?Upinsmoke Thanks this.
Page 1 of 3
