How are most semi transmissions lubricated?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by johnnyh55, Jul 27, 2015.
  1. johnnyh55
    johnnyh55 Bobtail Member
    16
    Aug 6, 2012
    Do they have a pump that runs off engine power? Is that the reason for dropping the driveshaft when towed, because the gears will run dry?
  3. mitrucker
    mitrucker Road Train Member
    5,164
    8,911
    Dec 15, 2010
    Lapeer, MI
    Transmission case has gear oil in it. Oil is flung around by the turning gears. Driveshaft is disconnected from the rear axle so the transmission is not damaged during towing. When the driveshaft is disconnected in this way, the transmission gears do not move.
  4. johnnyh55
    16
    Aug 6, 2012
    Ok, so it should not be done but if you would hold the cutch and put the tranny in gear both shafts would be tuning hence lubricating the transmission while being towed? Just trying to figure out how the lubrication works, I assume its splash lubrication only, no pump required?
  5. mitrucker
    5,164
    8,911
    Dec 15, 2010
    Lapeer, MI
    Correct. Splash only. ALWAYS disconnect the driveshaft when towing. Remember, the engine and transmission are hooked together.
  6. johnnyh55
    16
    Aug 6, 2012
    So if you pull an axle instead of removing the driveshaft, only one side per diff assembly needs to be removed? As soon as one axle is missing, it will not turn the transmission gears?
  7. mitrucker
    5,164
    8,911
    Dec 15, 2010
    Lapeer, MI
    Dont know about that. The accepted practice is to unhook the driveshaft from the rear axle.
  8. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Allot of towing companies just pull one axle out and put cardboard over the hole.
    With a tube out, I'll spin the spider gears instead of the driveshaft as it's the least resistance.
  9. AModelCat
    155,702
    There actually is a pump in most transmissioms, driven off one countershaft. Usually supplies the cooler circuit and the return oil gets routed to critical areas. Ultimately the goal when towing a truck is to prevent the transmission from being turned with the engine off so it doesn't fail due to lack of lubrication.
    magoo68 and Straight Stacks Thank this.
  10. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    if they can't tow from the back then they are pulling the shaft, I would never let a tow truck driver pull my axle.
    I work with a guy who flat towed his rig a week after a motor rebuild. he now has a new new rebuilt motor and tranny, everything heated up so bad it melted.
  11. brian991219
    brian991219 Road Train Member
    2,925
    5,821
    Aug 10, 2013
    Lords Valley, PA
    As a tower with over 20 years in the field, and a diesel mechanic, it is preferred to pull the driveshaft but some pressed in u-joints are difficult to remove or there is driveshaft damage so it is acceptable to pull axles. DO NOT let the tower pull only one axle, this will cause the differential spider gear to overheat and damage your differential, pull ALL 4 axles or the driveshaft.
    The axles in a heavy duty truck are full floaters, so there is no chance of damaging anything by pulling them, just be sure they put a real axle cap on it not just some old piece of cardboard or rag stuffed in the hole. Granted, on some differentials you have to lock in the locker or you may drop the pin which will cause damage, but generally speaking it is just as safe, if not safer to pull the axles. When pulling the driveshaft the tower has to be sure to "unload" the tension or they could be seriously hurt, plus if it is a timed shaft they could mess up the timing if they pull it all the way out from the truck, I recommend just disconnecting the shaft from the front differential and tying it to the frame rail with a strong strap or mechanic wire. It is also imperative to use new strap and bolt kit when reinstalling, the straps and bolts stretch and are one time use only. This is why as a tower I will not reinstall a driveline, ever, not going to take the liability for it.
