How bad are cold starts?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by razor1983, Dec 21, 2020.
  1. razor1983
    razor1983 Medium Load Member
    500
    509
    Jan 17, 2011
    It takes about 5-10 seconds for the oil pressure at 15F that oil is thick as molasses.
    How much damage is being done?
  3. RubyEagle
    RubyEagle Medium Load Member
    632
    788
    Apr 17, 2010
    When l was home during the summer l had to go start the truck every day or so to keep the batteries charged. Next oil sample they noticed higher than normal lead from the bearings probably due to all the cold starts. Next oil sample when back on the road lead was back to normal.
    Rideandrepair and razor1983 Thank this.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    If its going to be a regular thing , run a synthetic oil in it. Your not doing it any good, that's for sure.
  5. AModelCat
    159,363
    Use the proper oil grade for your climate.
  6. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    Depends on how long it has been sitting. A few days and the bearings are still wet. If you are in frigid temps I would throw a few quarts of 5w-20 synthetic in just to help keep them lubricated.
  7. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Someone said it already....oil for your climate and/or the very least synthetic if its going to be a regular thing.
  8. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    Any electricity where you park? How about a pan heater
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    If you don't have access to plug in just be easy on it. Let idle at 650 for the 1st 10min then bump it up to build some heat. Cold starts aren't easy on em that's for sure. If it only sits over night/weekend you still have a bit of oil left on top
  10. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    You guys would freak at the cold starts I dealt with when I worked in the rental business at Caterpillar. Generators dont have an idle speed normally, just straight to 1800rpm. And to hear a 3516 crank up at 30-40 degrees, go to 1800rpm with in 5 seconds of hitting the start switch is rather fun. It gets real fun when it goes into cold mode and start randomly dropping 4 or 6 cylinders at a time to warm itself up.
  11. AModelCat
    159,363
    Lol I used to deal with gensets a lot too. We'd be firing them up at -30 and like you said, full send to 1800 RPM!
    Shawn2130, Roberts450 and lester Thank this.
