how bad is this??? found it in my oil pan
Discussion in 'Trucks [ Eighteen Wheelers ]' started by buddyvuk, Mar 2, 2014.
  1. buddyvuk
    buddyvuk Medium Load Member
    337
    66
    Jan 6, 2013
    portland oregon
    Yesterday I was getting my oil changed and they found this in my oil pan. The freightliner mechanic thinks its bullgear and i need to change it asap. he said i am running on borrowed time. My personal mechanic thinks its my compressor ( since its leaking oil bad anyways)
    what do you guys think??? how bad is this and how soon i need to change this?
    bull gear is 800 but to change it its going to be at least 2500$ in labor costs.
    the truck is 2003 freightliner century with 12.7 ltr detroit . 855,000 miles IMG_20140228_134755827 (2).jpg
  3. buddyvuk
    337
    66
    Jan 6, 2013
    portland oregon
    btw..i am 6'7" so i have huige fingers , so those metal peaces are pretty big
  4. Poneill.45
    Poneill.45 Bobtail Member
    24
    20
    Jul 17, 2013
    IMO, best way to know for sure, is to get a rebuild kit for the compressor, and inspect the bearings, if you don't find a bearing that looks like the owner of those rollers, then you may be on to the bull gear. But it's definitely good to start with come thing you know needs done and less costly, than to go for the big item and be wrong.
    buddyvuk and puncher Thank this.
  5. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    If the air compressor spit those parts out......it wouldn't be just pushing oil.
    I'm not a detroit person, but I'd say the Freightliner mechanic has a vast knowledge of Detroit engines. I'd take his advise, because a total bull gear failure, becomes a rebuild.
    puncher, Deezl Smoke and buddyvuk Thank this.
  6. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    You can pull of the cover for the cam and turn the motor looking to see the bull gear, you can pull the air compressor and look and feel the bull gear. Either way it only costs a gasket to be sure.
    What ever you do running it is not going to get cheaper to fix.
    Just a thought!
    DL550CAT, Joetro, CondoCruiser and 3 others Thank this.
  7. truckereddy
    truckereddy Bobtail Member
    37
    7
    Feb 28, 2014
    highway usa
    they say bull gear often goes bad in detroits. good luck keep us posted where the metal came from.
    buddyvuk Thanks this.
  8. Rock hauler
    Rock hauler Light Load Member
    264
    54
    Nov 26, 2008
    Deridder La.
    had Detroit do that to me and it was compressor
    losttrucker and buddyvuk Thank this.
  9. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    1st replace or rebuild the compressor but pull it apart. They are simple machines. Just a piston, rings and valves. Be sure and save the little coke can thick dime size valve. We used to rebuild them in the field on bullwagons and it only took about an hr., even made valves out of coke cans.
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    was told by a 25 year detroit mechanic at williams that I needed a inframe due metal in oil & coolant in oil. turned out to be compressor on the coolant in the oil & the bull gear BEARING on the metal. after over 2 weeks downtime & a lot of money, I still had both symptoms. then they changed the compressor head & that solved the coolant in oil. ran a month then put bull gear in & solved the metal in oil problem. the only reason I did not mind as much as some might on the misdiagnosis is the engine had over 1.3 mil miles, so it was time for some peace of mind having this done reguardless.
  11. EZX1100
    EZX1100 Road Train Member
    4,017
    5,712
    Aug 18, 2012
    i dont have my pics, but mine looked the exact same
    it was scored metal from my crankshaft and bearings, either from wear or low oil
    i had to get the whole thing rebuilt (good for tax write off, bad for wallet)
