How can I increase power to my Detroit 11.1L S60 (350 HP rated) Series engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ivesti, May 29, 2021.
  1. ivesti
    ivesti Bobtail Member
    5
    10
    May 29, 2021
    Hi guys, I have a Detroit 11.1L rated at 350 HP and would like to know what changes I should make to the engine to increase power? Can I convert it into a 12.7L? Should I change the injectors? Turbo? Camshaft?
    I need advice how to approach this. I need at least 400 HP so I can run properly.
    Thank you in advance,
    George
    Rideandrepair and jamespmack Thank this.
  3. jamespmack
    216,319
    We are not allowed to speak of this work on this forum.
    But the guy you want is in Turbotvillle PA.
    Rideandrepair Thanks this.
  4. ivesti
    5
    10
    May 29, 2021
    Thank you sir!
  5. AModelCat
    161,299
    I thought it was just emission deletes we couldn't talk about?????
  6. jamespmack
    216,319
    Well idk. But the gentleman I speak of is not allowed on here because of his performance background.
  7. Rideandrepair
    17,430
    56,538
    Aug 8, 2015
    The cranks different. Longer stroke. Bore is the same. Rods are the same. pistons probably the same. I’d imagine cam and injectors are different. ECM the same, different program I’d guess. Depending on what you’ve got now. What year etc. You can build one using drilled rods. Some of the blocks had piston cooler nozzles, some were drilled for them, and can be added. I think it’s May of 98, all blocks were drilled. Mid to late 90s I believe is when upper cooling jackets were added to the blocks. You may be better off getting a new block with crank, or a whole engine. Build it how you want. A lot would depend on cost and what you have now. That’s my rough understanding. I think they can program yours to 400 hp. 1350 torque. Without changing anything. No emissions changes either. A little more power, might be all you need. The 11.1 is very good on fuel. Better than the 12.7s Dont burn much idling either.
    lwlevens, Swine hauler and jamespmack Thank this.
  8. Rideandrepair
    17,430
    56,538
    Aug 8, 2015
    Cranks different, rod lengths are the same. So pistons, though they have same bore, can’t be the same. Have to be taller. Heads are the same.
    Swine hauler Thanks this.
  9. ivesti
    5
    10
    May 29, 2021
    Thank you very much for your input. It's a 1997 year model. I am trying to figure out if it's worth to make any upgrades versus changing the whole engine to a 12.7L.
  10. Brandt
    Brandt Road Train Member
    4,595
    6,306
    Sep 17, 2012
    Pittsburgh power can probably get more power. They keep everything legal. They even work on fixing the new emissions engine keeping it legal.
  11. Big Road Skateboard
    6,646
    37,321
    May 2, 2021
    You'd be cheaper buying an engine complete. There are several plug and play options for the post DDEC 2 11.1, and they are quite impressive.
