How close can the vehicles be strapped next to each other?
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Atlanticus trucking, May 28, 2019.
  1. Atlanticus trucking
    Atlanticus trucking Light Load Member
    227
    125
    Jun 22, 2018
    how much space is needed between vehicles bumpers to avoid them hitting each other when driving? This is with using over the tire straps.
    does the suspension have play forward and backwards that would cause them to hit at a certain point? Thanks
  3. pavrom
    pavrom Road Train Member
    3,194
    7,317
    Apr 29, 2012
    NE illinois
    Enough to deliver it from point A to point B without damage
    Some drive with 1" between , some wanna have 5" to avoid troubles , depending on driving habit and road you drive ...i once had my bar on the bottom rail driven for 20 miles
    BigBob410 and Hammer166 Thank this.
  4. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
    It better not, or that's one worn out front end. Up and down, but if the tires are strapped, it shouldn't go anywhere front to back.
    Atlanticus trucking Thanks this.
  5. bamanation
    bamanation Heavy Load Member
    797
    915
    Jan 22, 2009
    Muscle Shoals ,AL
    You’ll be fine at three inches. For me Anything closer than that makes me nervous. There has been a few times that I’ve run it closer than that and it stressed me out worrying about it.
  6. rulonwaholla
    rulonwaholla Light Load Member
    258
    177
    Nov 6, 2013
    make a punch put it between the two cars and you good to go.
  7. NuCar Carrier
    NuCar Carrier Light Load Member
    132
    314
    Jan 23, 2016
    When you watch a vehicle bounce it's deceiving, the vehicle is only bouncing half the distance from it's static point.
    They do seem to travel up more than down but that's a guess.
    If you really want to find out exactly you could try what I've seen OEMs do and mount a play-do like substance at possible contact points.
    interpreter Thanks this.
  8. Atlanticus trucking
    227
    125
    Jun 22, 2018
    the issue is our choice was run at less then half a inch, or leave one. we left it.
  9. Atlanticus trucking
    227
    125
    Jun 22, 2018
    a punch?
  10. 24kHotshot
    24kHotshot Heavy Load Member
    801
    874
    Feb 19, 2019
    New York
    A closed fist.
  11. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    One other note, even with over the tire straps, I run as close as a fingertip on some loads, (sometimes you just have too) BUT if you pay close attention to what holes you are using for your hooks "can" make a difference in movement, IOW if you dont want the car to move, make SURE that your hooks are as close as you can get to the edge of the tire, in an extreme situation, like I will be very close on the tilt lift deck, I will hook my straps first, THEN back the car slightly onto the hook so I can grab maybe another hole at the front edge of the tire, that car, even on a 35 degree angle, will not move, just my humble opinion.
    yb226 and Ziggy319 Thank this.
