how common are the compress natural gas trucks??
Discussion in 'Questions From New Drivers' started by Ruckie, Feb 15, 2012.
  1. Ruckie
    Ruckie Road Train Member
    1,485
    1,029
    Nov 12, 2011
    Bloom field,nj
    I was driving thru Illinois and I saw 2 ruan trucks with that instead of the diesel tanks I was just wondering
  3. rocknsand
    rocknsand Medium Load Member
    563
    256
    Dec 28, 2007
    Tonganoxie, KS
    I think this is going to be the future fuel for diesel trucks, but you need fueling stations. I expect it will have to start out with the local trucks first, due to fueling stations, and the confidence builds, then it will expand for long haul trucks.
  4. Crusty
    Crusty <b>Just Plain Crusty</b>
    345
    140
    May 29, 2010
    Canton, GA
    The other day I heard contracts were being drawn up for Flying J and Pilot to install Nat gas tanks nationwide.
  5. irishwarrior
    irishwarrior Medium Load Member
    414
    1,240
    Dec 21, 2011
    williamsburg iowa
  6. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    10,061
    7,055
    Jul 15, 2007
    TEXAS
    I seen one yesterday on I-35 from one of the big trucking companies. Day cab truck with a steel enclosed rack behind the day cab pulling a 53' trailer. I had to do a double take, because at first, I thought it was a sleeper. A mighty small sleeper :biggrin_25523:
  7. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    This raises some questions. First, how competitively priced will CNG be per unit of energy as compared to diesel fuel? Second, what kind of range will CNG provide? How much weight will the beefier CNG tanks add to the curb weight of the truck, and will this limit loading capacity?
    A benefit that I can see is that trucks could go 'dual fuel'. Up to 90% of your fuel consumed would be CNG, with the remaining 10% as injected diesel in lieu of installing spark ignition to fire the CNG (compression ignition alone won't work for CNG). You'd need a specialized computer and metering system to work with the turbocharger, but it shouldn't be that difficult.
  8. jimvrg
    jimvrg Medium Load Member
    301
    83
    Jan 11, 2012
    yellville arkansas
    in a accident wouldnt that be more dangerous than diesel?
  9. jtc
    jtc Bobtail Member
    43
    5
    Jan 25, 2012
    los angeles ca
    no spills or explosions cng evaporates like freon i know a guy who leases one he says it doesnt pull as good as a diesel engine not many places to fuel also you need to purge the tank before fueling or the fuel guage will read more then there really is but its about a dollar cheaper then diesel
  10. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I'd say it depends. The tanks are heavier, and less easily punctured. CNG ignites easier than diesel, but it contains less energy by volume. Escaping gas would be less likely to find an ignition source, as NG is lighter than air and won't collect along the ground like LP. A fire wouldn't spread across the ground and burn for hours, it would likely be a single jet of flame that wouldn't last long. Unlike LP (or diesel), the NG is not in liquid form, so there's no danger of a BLEVE.
  11. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Whatever fuel is going to replace cheap diesel fuel you will not see it over night. The infrastructure took many years to establish so it's not just going to be rolled out. It may come in slowly but only when diesel is not making them money. If Wall Street would have stayed out of the picture maybe we could have had a decentprice on diesel fuel and we would all be making more.
    I would guess the CNG would first come out in large tanks to supply the tractor enough so the drivers doesn't need to refuel. But any time you bring in a new fuel a very intensive study must be done to show a profit. After all no one is going to do it because it's nice. Monetary advantages are what drives any business. I really think you'll start to see many types of fuels and designs changes coming slow with the mixture of what is already proven.
