How common is it for a shipper / broker with a dry van load to refuse to load a reefer?
Discussion in 'Ask An Owner Operator' started by windsmith, Apr 28, 2018.
  1. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,269
    Apr 19, 2018
    3000 pounds on average
    slow.rider Thanks this.
  3. "B"
    "B" Light Load Member
    64
    46
    May 1, 2016
    San Antonio, TX
    Honestly, it really depends on what you are hauling. If it's something that shouldn't be exposed to moisture then they will. Or if it's something like oil or the likes they may ask if you are sure if you want to haul it in the reefer because you can't just pick up anreefer load right after hauling stuff like that.
  4. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    It depends on a whole lot of variables. Newer reefer trailers are coming out at around 13,000 if you have aluminum wheels and the smaller fuel tanks. A dry van with a wooden floor can weight that much or more. Most places are going all aluminum these days because of fuel economy, but there are still some holdouts for the wood floors which are quite a bit heavier.
    KB3MMX Thanks this.
  5. rollin coal
    rollin coal Road Train Member
    13,288
    26,799
    Mar 29, 2008
    TN
    I can scale 45,000 lbs in the reefer I pull and 47,000 lbs in the van. Both are Great Danes. Some reefers have e-tracks. Some even have logistics posts but that would be unusual. Mine doesn't have e-tracks but I have hauled plenty of temp control loads of palletized 55 gallon drums of liquid or even totes that were easily secured using ordinary load locks. I like having both options available. Actually three options for me as power only availability also. I would really like to also have a 48 spread axle flat to take advantage of late winter early spring open deck rates.
  6. GreenPete359
    GreenPete359 Road Train Member
    2,152
    5,101
    Oct 21, 2017
    Driving my recliner
    Explain please. a clean trailer is a clean trailer. As long as it was swept out or washed out...no fumes/odors/debris, then your last load has absolutely no bearing on you next load.
    I don’t get your point, unless you mean if there was a spill??? If so, that would be a major issue van or reffer. Just wait untill epa gets a hold of you.
  7. SteveScott
    4,897
    16,806
    Nov 10, 2015
    I hauled a load of onions last year. Did a wash out and it still stunk a month later.
  8. Atlanta trucker
    Atlanta trucker Road Train Member
    1,602
    2,001
    Jan 25, 2017
    Yes it does happen but not very often. It happens also because a reefer is a few thousand pounds heavier than a dry van.
  9. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Amen!
    I'll add recycled plastic to that list ... What a tough odor to get rid of !!
  10. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,994
    9,709
    Oct 18, 2010
    NW Indiana
    There is no such thing as a totally versatile piece of equipment. Don't even try. Pick the area you want to service, match the equipment for that service. Ask the guys with flatbeds. Sometimes they miss out because they have a stepdeck, sometimes they make a killing. Same goes for reefer/van. it all comes out in the averages.
    Don't even think about getting into tankers....
    slow.rider and windsmith Thank this.
  11. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    I skipped a few good paying back haul loads of beverages back in January, afraid that low temps could be an issue, even though the brokers said that they would use blankets but somehow it did not convince me, reefer would have helped but then they would have not loaded the reefer with my outbound freight such as store shelving or paper rolls. With paper rolls it is up to the shipper, some load it on a reefer some don't.. A while back, as a company driver, we used to load paper rolls on reefers every week to take them to the West Coast...old beat up reefers, sometimes smelling onions but now I see on loadboards "van(no reefer)" when you go to paper mills and such.
