How do flat spotted tires wear
Discussion in 'Experienced Truckers' Advice' started by Big Road Skateboard, Jun 13, 2024.
  1. Big Road Skateboard
    6,721
    37,835
    May 2, 2021
    If you offset the flat spots? I've done this a bunch for past customers, but never saw any wear out.
    My son changed 8 for one of his customers. 2YO casing XDN2's. Tread depth on all the tires is 23-24/32"'s, and the deepest flat spot has a tread depth of 19/32".
    Has anybody gotten significant mileage out of a tire under these circumstances? I can get em for a little over 100$ a tire
  3. Cat sdp
    Cat sdp . .
    21,196
    75,208
    Apr 8, 2012
    Orion's Belt
    I’ve put fronts that rivered and basically had flat spots starting and moved them back.
    I run max air pressure and they wore fine….
    I’d probably try it
  4. Big Road Skateboard
    6,721
    37,835
    May 2, 2021
    Yeah, think I'm gonna have to at that price. If my current XDN2's last till end of summer, I'll have 360-370k on them. They're at 7/32" now.
    If I get 100k out of them I'm money ahead
  5. Long FLD
    Long FLD Road Train Member
    12,529
    52,078
    Mar 4, 2015
    For $800 I’d try them and see what happens.
  6. Rideandrepair
    17,448
    56,615
    Aug 8, 2015
    My experience is the tires only as good as it’s flat spot. That’s on a Trailer. Doesn’t matter 1 or 2. Doesn’t matter if mounted opposite. They wear out at the flat spot, or river wear, cupping gets worse. The exception is on drives. Just the opposite. I’ve ran old steers with a worn outer edge, river wear, cupped. Doesn’t matter. They’ll run forever wearing only the good tread. Outer edge doesn’t get any worse. I can only imagine it’s because of torque vs. free spinning Trailer tires? Maybe bad shocks on Trailer? No idea. Whatever the reason. I’ve seen it time and time again. I’ve only bought 12 new drives since 2009. 1.7 mil miles. Lol. Always new steer’s every 130-150k. Right one wears on outside edge. I’ve sometimes waited too long. Put old steers on drive, side by side worn edge inside of inner. Tire lasts just as long as the evenly worn steer. Usually another 130-150k till I buy another set of steers.
    aussiejosh, Cat sdp, Long FLD and 2 others Thank this.
  7. snowwy
    snowwy Road Train Member
    20,591
    13,311
    Jul 6, 2009
    You'll never wear the tire out to be even with the flat. It'll always be the low point.
    W923, MACK E-6 and Big Road Skateboard Thank this.
  8. Big Road Skateboard
    6,721
    37,835
    May 2, 2021
    Appreciate the replys guys. I got home last night and checked em out thid morning. These were brand new drives and the transporter drug them just a bit.
    I bought em
  9. aussiejosh
    aussiejosh Road Train Member
    4,768
    5,578
    Aug 28, 2009
    Airlie Beach QLd
    Technically they would be considered unroadworthy, however not so bad if you used them on the rear of the trailer, I would never run them on the drives, and definitely a no for the steers. But you can still get a lot of life out of them.
  10. Cat sdp
    Cat sdp . .
    21,196
    75,208
    Apr 8, 2012
    Orion's Belt
    As long as they measure 2/32 and don’t have cuts they are legal.
    At least here in the new 3rd world
    W923 Thanks this.
  11. Magoo1968
    Magoo1968 Road Train Member
    2,050
    5,466
    Mar 18, 2021
    St Malo mb
    Years ago didn’t some people spin balance tires and use a chisel or some sort of knife to cut high spots .. As long as they don’t thump I’d run them it’s a relatively soft sidewall so it might not be bad.
    W923 and Big Road Skateboard Thank this.
