How do get around an ELB
Discussion in 'Trucking Industry Regulations' started by Loaderlou, Dec 10, 2017.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    Im primarily within the 100 mile radius for most of the year except for maybe 30 days when I help a friend during a seasonal contract. I do travel 5 states but they are as if I'm running local. Is there a legal way around this or do I have to comply with it. And does that make my whole year subject to the new rules?
  3. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Once you hit the 9th day in 30 requiring a log, you must have an ELD. Once you are back inside the 8 days in 30, you can unplug it again.
  4. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,542
    May 22, 2017
    If you are home within 6 days you are exempt. I read this on a fmcsa page. Or just drive an old truck.
    slickWillie1980 Thanks this.
  5. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    My truck is an 01. I am going to operate under the 100 air mile radius exemption as well. You need to go on and off duty in the same location every day. Use the 8/30 exemption for longer distances but those you need to log on paper. Other wise just fill out one of these.
    brian991219 Thanks this.
  6. 201
    201 Road Train Member
    12,259
    25,030
    Apr 16, 2014
    high plains colorado
    I know an O/O that is currently going through this BS with an '01 Freightliner. He said, it's not so much the truck, it's the motor. If it has an ECM, you need an ELD. Is that true?
  7. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    If you can not run with a eld you have been fudging the numbers and hurting yourself. There should be no difference in the hours of service between the two so in the time we are forced to play the regulators game we should be putting a surcharge on all freight to cover the costs of doing business the way the regulators demand.
  8. Derailed
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    I am not fudging anything. I legally am not required to have one. I don't run outside of 100 miles from my home terminal anymore than 2 to 3 times a month tops. Sorry but I am not going to spend the money to buy one and the monthly subscription if i don't have to.
  9. pmdriver
    2,338
    3,503
    Nov 14, 2017
    I would not either unless it can be added to the cost of doing business by charging more for the service provided, even tho I buy stuff that trucks have brought to the stores it is going to have to happen until the sheep in this country wake up.
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Never mind the ELD. Im worried that at someone getting a bright idea to ban trucks after a certain model year as being non compliant...
    ELD or paper logs HOS is the same.
  11. Thane
    Thane Medium Load Member
    330
    307
    Mar 16, 2017
    Those who run Texas and STAY within Texas, but return to their starting points, can run Texas intrastate rules. I'm not 100% sure of the "return to their starting points" part of it. Texas rules may not have that restriction.
    GENERAL RULE - All Carriers - Intrastate In Texas (37 TAC 4.12) 12 Hour Rule (37 TAC 4.12(a)(2)) Drivers are allowed to drive for 12 hours following 8 consecutive hours off duty. 15 Hour Rule (37 TAC 4.12(a)(2)) A motor carrier cannot permit or require a driver to drive after 15 hours are spent on duty following 8 consecutive hours off-duty. NOTE: Drivers in intrastate commerce violating the 12 or 15 hour limits shall be placed out-ofservice for eight consecutive hours. • • • • • • • 70 Hour Rule (37 TAC 4.12(b)(2)) A motor carrier must not permit or require a driver to drive after having been on duty 70 total duty hours in seven days A driver may restart a 7 consecutive day period after taking 34 or more consecutive hours off-duty
