How do I drive with power steering?
Discussion in 'Questions From New Drivers' started by jasonkramer, Jul 22, 2013.
  1. wantabe
    wantabe Bobtail Member
    listen if it doesn't work out for you, operating a train may be your best option.
  3. coastie
    coastie Road Train Member
    That an option if he has a degree, and able to lift 80lbs It is also demanding if not more than trucking. I do have a cousin who on with Norfolk Southern He runs between Atlanta and Greenville SC mostly. He not allowed any other route as an engineer but can as a Conductor till qualified on them
  4. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    I have five overall suggestions for anyone with steering issues or lane control issues:
    1. Grip - your grip should not be "white knuckles". Think holding a golf club like Ben Hogan taught, "Hold it like you are holding a living sparrow and you don't want to crush it".
    2. Arm relaxation - one of the biggest problems for any driver is having tension in your arms. If you have arm tension then you start steering with your shoulders, and that's when you starting driving YANKee Doodle style. Whenever you have tension in your arms, immediately hang your elbows straight down and feel like your arms are heavy and suspended like a suspension bridge between your relaxed hands on the steering wheel and your shoulders. Driving in this manner gives you better feel for the road.
    3. Steering - it is best with the relaxed arms to steer by pulling down on one side of the steering wheel. The opposite hand should not be pushing up on the steering wheel, it should only be there as a guide.
    4. Visualization - one mental trick I have for having steady lane control is to imagine that I'm floating above the lane without any truck at all, just me flying along. I visualize flying about two feet left of the center of the lane and I "see" that line I need to take. It's kind of like snow skiing when you are trying to make a big giant slalom turn, you see the line, relax, and let the edges guide you through the turn.
    5. Presteering corners - at high speeds don't wait until you are in the corner to begin steering the corner. Start very slightly turning just before you get to the corner. This is a very slow turning of the wheel to initiate the turn. It will make a much smoother transition without yanking the wheel and putting a lot of outward G's on the truck. As the turn is finishing you start presteering the straightaway by slowly moving the wheel to the straight position.
  5. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    he might have to teleport himself back to 1972
    when drivers said power steering was going to make unsafe trucks
    because they couldn't feel the road
    God Bless power steering and automatics
  6. Lepton1
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    The first truck I drove was a '74 Ford cabover. The power steering was only active if your rpm's were high. One time I started taking a city turn with low rpm's and only had Armstrong steering, had to get it out of gear and rev it up to finish the hook turn. I still remember the bug eyed driver in the station wagon waiting in the turn lane, looking up at me as my truck came closer and closer...
  7. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    Often this type of over correcting a steering wheel is from focusing too close to the front of the vehicle. Try keeping your eyes further down the road and trusting your peripheral vision to hold you between the lines.
  8. JimmyBones
    JimmyBones Heavy Load Member
    968
    488
    May 14, 2011
    Baxley, GA
    I just want to be clear... This is a serious question and not a joke, right?
  9. VegasBiker
    VegasBiker Light Load Member
    89
    44
    Nov 4, 2013
    Vegas Baby!
    One time at trucking camp...
  10. Mountain Hummingbird
    Mountain Hummingbird Medium Load Member
    601
    399
    Oct 14, 2012
    Ok try this put you seat way up so that you can have one knee rub the bottom of the wheel, If you find you are still moving around in the lane alot put more upward force on the wheel with your knee.
  11. Numb
    Numb Crusty Curmudgeon
    4,238
    9,950
    Jan 30, 2012
    Charlotte, N.Carolina
    um.... learn to drive??
    if you do it in your pick up, you haven't learned to drive yet.
