How do I force a truck to idle?
Discussion in 'Questions From New Drivers' started by Driver0000, Jan 9, 2017.
  1. Driver0000
    Driver0000 Medium Load Member
    304
    320
    Jun 26, 2016
    Trucks set to no idle. Bunk heaters don't work. Slip seating in Volvos. Run a tight overnight and company says hotel is ok but run is tight and northeast.
    Short of rigging a stick to bump rpms, how can I idle this POS?
    Tried cruise with no luck.
  3. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Some trucks a stick wont even work. A adjustable snow brush or bar magnet can be modified to work. If the truck will take. We had 1 truck that cruise didn't override the shut off. Had a shop change the settings in the ecm..
  4. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Have you tried holding the cruise for a few seconds?
  5. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Many are temperature dependent ... parameters set by company policy. Inside a certain temp range, will refuse to idle beyond a certain time limit. To answer your question, it may not be possible.
    AtticusRoad and JReding Thank this.
  6. Driver0000
    304
    320
    Jun 26, 2016
    It's -8 here. Company was banking on the bunk heaters working.
  7. Driver0000
    304
    320
    Jun 26, 2016
    8. Not -8, oops.
    Still cold enough
  8. Lonesome
    Lonesome Mr. Sarcasm
    11,311
    23,273
    Dec 15, 2007
    Northern Indiana
    Some won't, without a change in the ECM settings. My 14 Cascadia would only idle 10 minutes, before shutting down. Shop had to reset the ECM, to run about 40 minutes.
  9. Texnmidwest
    Texnmidwest Light Load Member
    282
    428
    Mar 6, 2015
    Do you sleep in your truck? If so, demand they either fix it or get you into another truck. Be nice but firm. If they won't do that there are a lot of other companies that are looking for good drivers. -8 with no heat is in humane.
    Voorhees84, Badmon and JReding Thank this.
  10. KillingTime
    KillingTime Road Train Member
    3,865
    61,880
    Mar 26, 2016
    Rockland, Maine
    Well............... Lol.
    Grubby, Lepton1, j_martell and 6 others Thank this.
  11. Cat sdp
    Cat sdp . .
    21,069
    73,960
    Apr 8, 2012
    Orion's Belt
    Try setting the trailer brakes and leave the tractor brakes off and jam the accelerator petal with a screw driver or something .....
    It's worth a try.....
    G13Tomcat and Bean Jr. Thank this.
