How do I not make my truck smell like a ashtray?
Discussion in 'Questions From New Drivers' started by hanzpoo, Aug 19, 2010.
  1. hanzpoo
    hanzpoo Bobtail Member
    16
    5
    Aug 3, 2010
    Ada, Ok
    I just picked up my truck for my new job. The only problem I have besides it being filthy is that it smells like a freakin ash tray. It has ashes all over the floor and everything. I bought some febreez and air freshener, but is there anything that can help with this smell besides that?
  3. Mooney
    Mooney Road Train Member
    I remember reading leaving an open can of coffee grounds in it overnight.
    There's a thread here somewhere.
  4. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    on your days off----grab some paper towel---soak it in vanilla--leave it in truck with windows up----when you get back should be nice and fresh
  5. canuck in da truck
    4,352
    2,601
    Aug 6, 2010
    western pa
    used to use the coffee thing in trailers after they had a stinky load---works good
    and its a common drug smuggler trick--supposed to throw off the dogs i guess
  6. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    Clean the carpet and wash all hard surfaces, you will never get it out of the A/C.
    You did document it's condition and got signatures before accepting the truck, right?
    If not you may be held responsible for it's condition.....
  7. hanzpoo
    16
    5
    Aug 3, 2010
    Ada, Ok
    Thanks for the tips, I will try them all. Yes I took pictures and documented everything.
  8. scottccal
    scottccal Bobtail Member
    40
    san diego,ca
    As for the smell in the a/c vent's thier is a spray that you can use its call frigi fresh
    its made buy CorMax tech (aka BG products) alot of car dealerships sell it or you could
    check thier webpage and find someone who sells it , ive used it and it work's
    pretty good.
  9. Scott7975
    Scott7975 Light Load Member
    165
    38
    Aug 5, 2010
    Cortland, NY
    Lol nice sig. Thats my birthday!
  10. simplyred1962
    simplyred1962 Betty Boop, One Bodacious Babe!!!
    Here's a "trick" I was told...I've used it, and it works very well...place a scented dryer sheet in between a sheet of cheesecloth, on the A/C filter.
    Replace once a week. Not only does the scented dryer sheet make the truck smell nice, but the cheesecloth also keeps a lot of hairs, and dust, and debris off of your air filter, thus saving you having to replace the filter as often.
    Judi Kay
  11. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    there may already be dust and hair in there now. what i have done is use a can or 3.......of those "canned air" that you use for a computer. get under the passenger side footwell the best you can, and spray and blast as much of that air intake area you can. use up all the canned air you have. once this is as clean as possible, i would spray lysol disinfectant in there to kill off any germs. then do the drier sheet trick.
    also, if this truck is a sleeper, then you must repeat this process in the bunk a/c system as well.
    then what i would do is buy some "simple green" and with several clean rags, i'd get into every knook & cranny, and crevice in the sleeper interior, header(ceiling) the mattress, everywhere the smoke will permeate into.
    this is all going to take a long time to clean and deodorize. once the truck is as clean and odor free as possible, have a sign that says, "no smoking" and tape it to the dashboard, so that when a mechanic or other service person jumps in it, he will see the no smoking sign(s)........usually though, "most" service techs will not smoke in a truck as a matter of respect.
    simplyred1962 Thanks this.
