How do I override idle shutdown on a 2018 International?
Discussion in 'Experienced Truckers' Advice' started by BukowskiFlowers, May 19, 2019.
  1. BukowskiFlowers
    BukowskiFlowers Light Load Member
    60
    23
    Jan 24, 2017
    It's 76 degrees outside and the truck keeps shutting down. It just rained so maybe that is an issue? Because it idled fine at 63 degrees without shutdown.
  3. Opus
    121,109
    You don't. Your company does
  4. homeskillet
    homeskillet Road Train Member
    5,953
    44,477
    Jun 1, 2013
    Dayton, OH
    Opus is right.
    But you can try releasing the tractor brakes with the trailer brakes set, or bumping up the idle with the cruise control.
    That's all I got.
    Tb0n3, Omega1 and motocross25 Thank this.
  5. Powder Joints
    7,688
    7,785
    Sep 25, 2007
    Rosamond, SoCal
  6. GreenPete359
    GreenPete359 Road Train Member
    2,152
    5,101
    Oct 21, 2017
    Driving my recliner
    Ding Ding Ding. We have a winner
  7. A Bug
    A Bug Heavy Load Member
    905
    1,818
    Mar 15, 2014
    Sevierville TN
    My 2016 international is set to shut off after ten minutes of idling if the temperature is between 25 and 65.
    However right before it shuts down when the temperature is between that range I get a flashing light on the dash saying it is about to shut off. All I have to do is tap the accelerator and then the truck will keep idling indefinitely.
    D.Tibbitt Thanks this.
  8. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,032
    Dec 31, 2010
    Washington, PA
    The pedal tap is what my company has set. No temperature parameters set. We have APUs and no crazy fuel bonuses. I don’t think they watch idling at all because everyone is good about using APU.
  9. MGE Dawn
    MGE Dawn Road Train Member
    1,096
    2,285
    May 19, 2019
    Vancouver, WA
    Can confirm, bumping the idle on cruise is a fairly reliable way to defeat that infernal timer. Although I don't think that releasing the tractor brakes is necessarily a requirement for it to work... I sure as #### don't release my brakes, anyway
  10. UnknownJenkins
    UnknownJenkins Bobtail Member
    8
    My cruise idle is disabled and the pedal truck doesn't work either. I too have 19 LT but was told if you have unplug the outside temp sensor it will idle but I have no idea where.it located. Any thoughts?
  11. Moosetek13
    Moosetek13 Road Train Member
    14,683
    18,458
    Nov 1, 2010
    Burnsville, MN
    Won't doing that give a code reading for the time it is disconnected?
    If so, the next time the truck is in the company shop they will wonder why the code shows up when you have the truck but not when it is in the shop.
    Assuming you plugged it back in before you brought it in.
    Tampering with company equipment will get you fired pretty quickly. No warnings.
    And the high idle time is a dead giveaway.
    I can cheat my '17 Cascadia for 30 minutes by wedging my tire thumper between the seat and throttle.
    Give it just enough to barely raise the idle, as too much has little effect.
