How do I remove my 13 speed shifter knob?
Discussion in 'Mack Forum' started by gabbyjoe, Nov 17, 2011.
  1. gabbyjoe
    gabbyjoe Bobtail Member
    5
    Oct 30, 2011
    Hazleton, Pa.
    I want to take my 13 speed shift knob off, so I can remove the lockout tang, so I can shift the low side. I need specific instructions on how to remove the shift knob. I have no idea on how to take the knob off. Please help!!!
  3. walstib
    walstib Darkstar
    Sit on bunk and kick it! :biggrin_2559:
  4. Flightline
    Flightline Road Train Member
    2,345
    1,166
    Oct 1, 2011
    Almost There
    the top cover should just pop out with little prying. Then 3 little screws. There will be a little ball, don't lose or leave it out.
    I beleive you can't just use the spitter in low range like an 18 speed. I think your chasing a myth. Though taking the shifter apart is pretty simple.
  5. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    yup perfect way to make a trans go kaboom !!!!!!!!!!!!
  6. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    50 years ???? Don't play with your knob!!!!!
  7. dirthaller
    dirthaller Road Train Member
    1,109
    12,981
    Sep 22, 2011
    Coloratah
  8. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    no if its a Mack 13 you can make it a 18 by breaking the lock out tab or you can go to mack and by a 18sp gear shift and put it on there the exact same trans.
  9. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    What ?!..........................................
  10. Flightline
    2,345
    1,166
    Oct 1, 2011
    Almost There
    Please educate me but I've haven't seen a mack 13/18 speed transmission. Sure it isn't an Eaton Fuller? If so, you can change the knob but the 13 has weaker gears and using the splitter in the low side will break gears. Real bad idea.
  11. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    You've never seen a 13/18 speed Mack but you know Eaton 13 speed gears are weaker than 18 speeds? Eaton 13 speeds are the same trans as an 18 speed. $500 in parts will change a 13 speed into a 18. They use the same gears.
    Mack has trans from 5 speed thru 13, 15, 18, 20 speeds
