How do I use truckers report?
Discussion in 'Ask An Owner Operator' started by feldsforever, Jan 30, 2020.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    When I want to respond or quote. I can only capture the whole mesage. I see others know a way around this. Please help.
    2) searching in the search bar. I am able to find nice and decent threads. But can't quite get my search narrowed enough. To pin point. Any suggestions?
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    If you have a [ qoute ] and a message then [ /qoute ]
    You can edit the message and snip out the fat so to speak by deleting between the two boxes until you have what you want.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    You can highlight what you want to quote.
    Reply will quote just that while "quote" will add it to the multi quote list.
    PE_T, TallJoe, x1Heavy and 1 other person Thank this.
  5. DUNE-T
    DUNE-T Road Train Member
    6,944
    16,850
    May 10, 2015
    Detroit, MI
    Like this?
    x1Heavy Thanks this.
  6. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    here I can comment
    possible comment
    ok
    ok
    Ha! This is the first time I tried it. Works good...Thank you.
  7. ZVar
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    Have we created a monster? :)
    PE_T and Deere hunter Thank this.
  8. PE_T
    PE_T Road Train Member
    What ZVar said is the easiest way to quote one or more quotes from one or more members.
    Now if you already posted a comment in a thread, but you want to add a new quote, then this method won’t work. To solve this, you need to add another step to what ZVar says. So you follow what ZVar says, then you copy what gets generated at the bottom of the comment section. See images.
    ZVar Thanks this.
  9. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Yes
    PE_T Thanks this.
  10. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Nice thank you. I will read the next part now
    PE_T Thanks this.
