How do truckers power electronics are such in the truck
Discussion in 'Questions From New Drivers' started by biddlydiddly, Jan 22, 2018.
  1. biddlydiddly
    biddlydiddly Bobtail Member
    13
    6
    Jan 22, 2018
    I have heard by using an inverter, but that many companies don't allow it. How then, do truckers warm up food, charge phones/laptops or run tv in downtime?
    edit: I mean't to say 'and' such, not are.
  3. Maj. Jackhole
    Maj. Jackhole Heavy Load Member
    807
    4,202
    Mar 19, 2017
    There are cig lighter ports all over in the front and in the sleeper. Just get appliances that have cig port adapter.
  4. Tb0n3
    Tb0n3 Road Train Member
    4,540
    9,019
    Oct 5, 2012
    Earth
    Go to a company that has them installed. I wouldn't want to be in a truck without a decent inverter.
    Aamcotrans and NavigatorWife Thank this.
  5. Chinatown
    Chinatown Road Train Member
    74,669
    169,723
    Aug 28, 2011
    Henderson, NV & Orient
    Go to a company that has APU, this way you can shut off the truck engine, then crank up the APU and have plenty of power for electronic gadgets, plus have heat and air conditioning.
    When you're ready to change companies let us know and we'll help you find a company with APU. Where is your location; city/state?
    NavigatorWife, jammer910Z and Puppage Thank this.
  6. biddlydiddly
    13
    6
    Jan 22, 2018
    I live in CA and will work with CR England. Do they have a APU?
  7. ZVar
    ZVar Road Train Member
    10,911
    23,827
    Sep 10, 2010
    Flint, MI
    After all the information here and you are still planning on going to England. I weep for the human race.
  8. Tb0n3
    4,540
    9,019
    Oct 5, 2012
    Earth
    You should probably reconsider your choice of Crengland.
    Aamcotrans Thanks this.
  9. Short Fuse EOD
    2,772
    8,647
    Jul 29, 2015
    Midwest
    I would stay clear of a company that wouldn’t let you use an inverter. If they care that little for you, imagine all the other things that they will pull.
  10. IluvCATS
    IluvCATS Road Train Member
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    This OP is hell bent on CRE! Too funny.
    Kyle G. Thanks this.
  11. TruckRunner
    TruckRunner Heavy Load Member
    704
    3,270
    Dec 21, 2017
    The company I drive for used to have weak inverters so I installed my own 3500 watt one. People act like installing an inverter is rocket science. Red (positive) and black (negative) using low gauge wire which usually comes with the inverter and you are done. You can remove it if your company doesn't allow it when you go to their mechanics. Then wire it back when you leave.
