How do you add air to trailer tires without air inlet ports?
Discussion in 'Experienced Truckers' Advice' started by expedite_it, Feb 28, 2023.
  1. expedite_it
    expedite_it Road Train Member
    1,646
    863
    Sep 8, 2012
    Sometimes I get trailer tires that don't have air inlet ports to add air to the tire. Below is a photograph of such a tire: trailer tire.jpg
    These trailer tires without air inlet ports are always tandem tires, and there are always white tubes going from the hub oil seal to the inner tire on these trailer tires without air inlet ports. The only way I know of to check the air pressure on these tires is by thumping the tread with a hammer. There is no air inlet port to use a tire air pressure gauge. One time I had a trailer tire without an air inlet port like in the picture above, and the inner trailer tire was low on air. I didn't know how to add air to the trailer tire. If the outer tire was low on air, I wouldn't be able to add air to the outer tire either.
    How can a person add air to a trailer tire in the photograph above?
    tscottme Thanks this.
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Those white hoses attach to the valve stem on each tire, it looks like an auto-inflate system. Start the truck push red button in it should bring it up to 100 psi or whatever it is set to. Takes a few minutes, but works great. If it isn't inflating them, look for a hand valve maybe a dial somewhere at the front of your tandems, mine are inside a small box, can turn it off with the valve or turn the dial to change psi. If you are determined to use a tire gauge, you could unscrew the white hoses off. Do you have a light usually on the front left of your trailer, about where a reefer would have its lights, and does it light up with key on and red button in?
  4. kemosabi49
    10,659
    45,703
    Jan 13, 2013
    SW Arkansas
    That is an automatic air inflation system. It is designed to keep your tires inflated to proper pressure. If you have a leak there should be a white light at the front left corner of your trailer. If that's not on, you should be good to go.
    Tb0n3, Magoo1968, silverspur and 7 others Thank this.
  5. Lyle H
    Lyle H Road Train Member
    1,291
    2,937
    Apr 16, 2014
    Are you the guy that was drawing all the pictures about turn angles in another thread?
    With 12 years experience?
    Bud A., Bean Jr., Magoo1968 and 7 others Thank this.
  6. expedite_it
    1,646
    863
    Sep 8, 2012
    By "red button", do you mean the red brake valve?
    I have the light. The light does not light up with the key on and red button in.
    Rideandrepair Thanks this.
  7. expedite_it
    1,646
    863
    Sep 8, 2012
    If you click on my screen name, a new menu will pop up. Put the cursor over the number of messages I have made, and then click your mouse on that number. That will give you a list of all the messages that I've made. Then go back through my old posts to see if I drew pictures in other threads. If you'll read my previous posts, you will also find out how many years of experience I have. I will give you a hint though: It's less than 12 years of experience.
  8. tscottme
    tscottme Road Train Member
    Yes, push in the red valve on the truck dashboard, which is beside the yellow valve. No light = tire pressure OK.
    expedite_it, Tb0n3 and Rideandrepair Thank this.
  9. ZVar
    ZVar Road Train Member
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    Also note the white light is detecting air movement, not so much it inflating tires. So when you first hook up and the air tanks are empty, that light may be on for a few minutes while the tanks and suspension all equalize with the tractor.
    wis bang, Bean Jr., Mnmover99 and 4 others Thank this.
  10. Lyle H
    1,291
    2,937
    Apr 16, 2014
    Sorry , it was only around 8 years.
    Still makes me wonder the true purpose of the threads you create.
    After over 8 years of driving you have no idea how this works?
    I don’t believe you.
    Bud A., InTooDeep, Bean Jr. and 5 others Thank this.
  11. expedite_it
    1,646
    863
    Sep 8, 2012
    I don't care what you believe.
