How do you drivers overcome the hindrance of Swift not allowing inverters in trucks?
Discussion in 'Swift' started by Woppin Wild, Jan 19, 2013.
  1. Woppin Wild
    Woppin Wild Light Load Member
    76
    38
    Oct 24, 2007
    Ruskin, FL
    I'm probably going to be going to school with Swift in about a month's time, and the only thing that makes me a bit apprehensive about choosing them is their ban on inverters. My question to all of you is how to you deal with this while you're out on the road as far as what you eat, how you charge your laptops, and all of the other things that necessitate electrical power that requires an inverter in a truck. Having to eat every meal at the truck stop or fast food joint is both unhealthy and expensive, so how do you keep food costs down and your weight reasonable if you can't keep food on board and refrigerated?
  3. mitrucker
    mitrucker Road Train Member
    5,268
    9,346
    Dec 15, 2010
    Lapeer, MI
    Buy things that plug into 12 volt outlets. They make inverters that do (Cobra 400 watt model). I also have a Coleman powered cooler that plugs into my 12 volt outlet too. Works great. Keeps everything nice and cold. Talked to a guy in the truckstop here a little while ago, he has had his for 2-3 years he said. Still working great. ($80 at Walmart, $100+ at truckstops)
  4. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    Buy a 300w inverter that plugs into cig lighter. Take it out when you go to the shop for repairs.
    bluebonn Thanks this.
  5. superbdan
    superbdan Light Load Member
    65
    22
    Sep 14, 2012
    Eastern Washington state
    Never had a problem with a plug-in inverter as a company driver, they just don't want one wired in.
    Marky84 and bluebonn Thank this.
  6. walstib
    walstib Darkstar
    You'd think they'd want it wired in by their shop so they knew there won't be any problems, weird.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,683
    18,457
    Nov 1, 2010
    Burnsville, MN
    I don't hide mine when it goes into the shop and there has never been a problem.
    Just don't get one wired directly to the battery.
    Marky84 Thanks this.
  8. ralph
    1,112
    632
    Mar 1, 2009
    At The Key Board
    Maybe their mechanics have the same talent and aptitude as their drivers! :biggrin_25523:
    NavigatorWife and scottied67 Thank this.
  9. Woppin Wild
    76
    38
    Oct 24, 2007
    Ruskin, FL
    I was unaware that plug in inverters were allowed. I assumed that it was a sweeping ban on all inverters, but that's what I get for assuming. How many 12V outlets do trucks generally have?
  10. Sheriff1/6
    Sheriff1/6 Medium Load Member
    480
    505
    Oct 16, 2012
    Boise, ID
    Same as above. Just get the ones that plug in. I charge my laptop, cell phone, run my cooler, and cook with it. It does drain the batteries down and when it does I start the truck and let it idle. If you have to have a CPAP machine you buy a bigger inverter and Swift will wire it in for you. I have two friends that are going through that right now.
    My truck has four 12v sockets that I've been able to find.
    NavigatorWife Thanks this.
  11. pokerhound67
    pokerhound67 Heavy Load Member
    801
    665
    Oct 30, 2012
    i worked for a company that did not allow inverters in trucks...not installed or plug in type. i knew of not a single driver that did NOT use a plug in type inverter, taking it with them when going into a shop as previously suggested. completely unreasonable rules are just asking to be broken.
    Marky84 and NavigatorWife Thank this.
