How do you know when your vehicle is overloaded
Discussion in 'Questions From New Drivers' started by ichudov, Mar 16, 2012.
  1. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Let's say that I drive a truck with a flatbed and load a bunch of equipment.
    How can I possibly know whether I am overloaded if I do not know the weight of the stuff I loaded?
  3. sedain
    sedain Medium Load Member
    419
    328
    Dec 4, 2010
    well, your company likely reimburses for scaling loads,which can be done at most any truck stop. if there is any doubt as to whether youre ANYWHERE near being overweight you should scale it. anything over 25,000 lbs is a good place to start for a newbie.
    ive never done flatbed,but i dont know of any places that have drivers load cargo, 99% of the time the shipper will load, or it will be preloaded and youd be responsible for tarping, and securing the load and they might even help with that.. as far as dry van and loading cargo ive never loaded a trlr either, at most its "driver assist", likely all theyll have you do is verify piece count.
    the weight of the stuff SHOULD be on the bill of lading as well.
  4. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Its on the Bill of Lading - or it should be. Add that to the empty weight of your truck and trailer.
    Then go to the nearest public scale and weigh it - or plan on spending a lot of money in overweight fines.
  5. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    OK, guys, I am sorry, I realized that I was not clear. My fault.
    I do not work for anybody. I own my own company. I buy and sell industrial equipment. I have a little warehouse, buy stuff and sell stuff. Right now I use machinery movers to move anything over 6k lbs.
    As part of my business, I may go to an auction and buy 3-4 industrial machines. Then I need to move them.
    I am working right now on acquiring a class A transport capability. I already bought a Ford LNT9000 semi tractor, and am looking for a trailer.
    In those situations, there is no bill of lading, no one really knows how much the machines weigh, etc.
    So, with that in mind, I want to know if there is some straightforward way to look at the springs, or some such, and know when I am overloaded, so I do not get in trouble.
  6. ironpony
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Google "Right Weigh" - they have units for both tractors and trailers. When you're close to gross legal weight, you still need to scale it.
    Right Weigh Inc. Thanks this.
  7. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Thanks about suggesting this "right weigh". It seems that they require air bag suspension, right?
    For spring suspended tractor/trailers, is there some way to measure spring deflection and arrive to a weight. It should be relatively straightforward, no?
    Sorry if I am being dumb here. Just trying to see what my options are.
  8. sedain
    419
    328
    Dec 4, 2010
    no. you should be able to either ask about each machine's weight, or google it via your phone, but there is no way to check weight in that manner...doesnt work...weigh it at a licensed scale.
    the fine's for being overweight can be shocking depending on how poorly weight is distributed and the total weight versus what youre permitted for.
  9. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Google "on board scales for spring suspension", there are LOTS of places that cater to sprung big rigs. Not as cheap as the air ride gauges, which are just a glorified pressure gauge, but perfectly doable anyway.
    I would honestly look for an air ride tractor, or converting the tractor to air ride. Make it a much better ride, and be able to dump the air when needed. Not to mention the ease of fitting an air gauge to it.
    Most trailers have air ride, and can be fitted with a gauge no problem.
    You do not need a "right weigh" etc gauge, just a pressure gauge.
    I have the gauge on my RGN marked for 34,000lbs and 40,000lbs. Just scratched a line on the face of the gauge, then I can tell at a glance where my weight is. I haul permit loads, most of which are overweight too. I can go to 40,000lbs on the trailer pretty much anywhere with permits, so as long as I know I am under 40k for a permit load, or under 34k for a legal weight load, I am good to go.
    Forget about Cat scales etc when doing what you are doing, as you need to know there and then if you are overweight or not don't you? Most auction places I have loaded at don't appreciate you coming back to unload part of the load.
    A pair of gauges is your best bet IMHO.
    Martin
  10. Peterbeatinit
    Peterbeatinit Medium Load Member
    340
    120
    Mar 8, 2012
    San Antonio Tx
    CAT scales used to cost 8 bucks first weigh..then a 1.00 for each additional to adjust weight..they are all over the place..if you are only running locally and not going out of state across any DOT scales you'll be ok..just cat scale it..if its over..go back, have em pull one and make two trips.
    Petey
  11. leftlanetruckin
    3,607
    3,163
    Mar 12, 2009
    Little out of date there......$9.50 a pop now for the first weigh.
    Martin
    Mud Dog Thanks this.
