How do you load your compartments? ( fuel tanker )
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by dextrdog, Jan 18, 2015.
  1. dextrdog
    dextrdog Light Load Member
    124
    65
    Feb 2, 2012
    Milwaukee, WI
    I haul fuel and I was trained to load my compartments 3200(3500), 1600(2000), 1000(1200), 2800(2800)... I know everyone loads it differently. My trainer told me to never put more than 4800 in my first 2 compartments... Today I played around with it a little and put 3100 in #1 and 1700 into #2 instead of the usual 32 and 16....and I dunno if it's just in my head but I think noticed lot better handling on the freeway and in curves..... So I'm asking all the vets what is the best way?? I know there is tankers with different compartments
  3. 201
    201 Road Train Member
    12,069
    24,638
    Apr 16, 2014
    high plains colorado
    Hi dextrdog, I live in Milwaukee too (but not for long). Sounds like you took a little weight off the steer axle.
  4. walstib
    walstib Darkstar
    Since you have the ability to choose compartments/loading, do you load differently in the winter, like making sure your rear compartment gets weight for traction?
  5. plant
    plant Heavy Load Member
    806
    700
    Sep 21, 2012
    Los Angeles, CA
    First 2 on my truck is 3875 and 1975. Depending on temperature. Everyone's setup is different, semis and T&Ts are different, and since your company will want to maximize revenue per load, they should have already scaled out their trucks to see what their maximum capacity is.
  6. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    The only way you'll know for sure is load it up and scale it. We had a small truck like that so we could run AZ once in awhile. But it was a truck and trailer so we loaded completely different than semi's. The last time we run semi's is when the east coast shut down for us and they moved the better one out west. A semi is just too much waste for us. You can count on running lighter on your steers since you shifted 100 gallons. What would be your advantage of doing that? Is it because of product selection or your handling of the truck? You're grossing 8600 and we could gross 9000 with the truck and trailer. But like I said the only way you'll know for sure is fuel your truck to the max, load the way you want to then weigh the truck with you in it. If your doing it for handling reasons I'd say load back your 100 gallons on your first compartment then shift 100 gallons to your last. Sorry I couldn't be much help.
    DrtyDiesel Thanks this.
  7. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    We have 5 compartments
    3100, 1200, 1100, 1000, 2800.
    I usually load however I need to but I don't go over scales very often. I usually like to keep weight on the front end since I don't deal with snow or ice so traction on the trailer wheels isn't a big deal.
    I'd say load it how it feels right for you and what you're comfortable with
    Gr8oldies Thanks this.
  8. Second Gear
    Second Gear Bobtail Member
    12
    Jan 10, 2015
    Dumb question....are those numbers in gallons?
  9. bulkhauler
    bulkhauler Bobtail Member
    38
    7
    Feb 25, 2007
    I load my like this #1 3100 (3400) #2 1800 (2000) # 3 1000 (1100) #4 2600 (2700) scales out good.
  10. DrtyDiesel
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    Mine are.
    Forgot to mention that, especially if we were talking liters if someone is from Canada
  11. Second Gear
    12
    Jan 10, 2015
    If gas weighs 7 pounds per gallon that's over 60,000 pounds right?
