How do you prepare for the cold without idling.Genset , electric blanket etc.
Discussion in 'Ask An Owner Operator' started by henboy1, Oct 28, 2019.
  1. henboy1
    henboy1 Medium Load Member
    331
    139
    Mar 26, 2011
    stockbridge
    I have a genset for the portable heater and I have a cut out cardboard for the front of the radiator for when going down the road.I also have a portable electric heater which plugs to the genset .I bought Mr.Heater, a propane heater.I got the long johns and winter thermal hat
    I am thinking on getting an elctric blanket that will plug into a 2000 watt cobra inverter. My question is, how much wattage are they drawing from the wattage.I just dont need anything over 30watts that will run for about 8hrs during the night.Some nights I just dont want to crank up the Genset.
    You APU owners always wanna knock Gensets.Please stay in your lane and dont come on this post.
    How are you guys preparing?REMEMBER, SOOTH IS YOUR ENGINE"S KILLER!
    D.Tibbitt Thanks this.
  3. Tug Toy
    Tug Toy Road Train Member
    6,983
    73,111
    Jul 4, 2015
    Corn field
    I have a gas generator. 800 / 1200 watt heater and a battery charger that runs when the generator is running.
    Best thing I ever did was buy a heated blanket last year. I use it under the sheet. What a world of difference it made.
    Our company trucks have bunk heaters but the either cooked you out of the truck or just plain not work at all.
    this on low dose everything I need in the Midwest
    My winter generator can run 10 hours on 1 gallon of gas.
    During the summer I use a bigger unit that uses 3 gallons a night with the AC running.
  4. D.Tibbitt
    148,960
    without idling? i use the bunk heater down til about 0 degrees, anything under that and im idling. it aint worth the risk of having dead batteries in the morning.
  5. henboy1
    331
    139
    Mar 26, 2011
    stockbridge
    Wow.You got the best generator.You mean gas , as in gasoline?1 gallon that last 10 hrs must be a small engine.My RYOBI 3600 uses about .3 gallons every hr and about 4 gallons in 12 hrs.Is the charger separate from the Genset?I have never bought a generator that can actually charge a big truck battery.All the chargers I purchased had to be separate from the genset.How many watts is your heated Blanket?
  6. henboy1
    331
    139
    Mar 26, 2011
    stockbridge
    Yes, you are right.Definitely have to idle at those temps.My problem was keeping the heat maintained going down the road.Now, I just insert a carboard in between the cooler and the radiator
  7. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    Yeesh am I the only one to keep a Atlantic hurricane lantern on hand and some lamp oil?
    D.Tibbitt and henboy1 Thank this.
  8. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    :eek::eek::eek::D:D:D:D
    I am not serious posting this but this could keep you warm when stuck in Rawlins, WY in a blizzard...
  9. henboy1
    331
    139
    Mar 26, 2011
    stockbridge
    Alchohol in a CDL truck.lol.alrighty then
  10. speedyk
    speedyk Road Train Member
    1,837
    2,470
    Apr 8, 2015
    Wool undergear is much warmer, also more expensive but worth it the first night. Can wear for weeks without stinking. Never put in dryer or warm wash. Comes in weights, start with thinest and thickest, look for sales at outdoor suppliers.
    Expedition-grade down sleeping bag, keep it in the big bag not the compressed one and it will last for years. I'm still using an older Marmot Never Summer zero degree bag bought cheap a decade ago. I can drop inside it until only my nose sticks out if needed, it weighs in ounces.
    Quilted insulated pants, these are usually for mountain climbers, will go under regular pants like long johns and sometimes have windproof Pertex shell. I love standing out in the cold wind feeling warm while the person I'm talking to is shivering and wondering if I'm superman. :^)
    You can also wear them to bed, helps warm up that cold sleeping bag.
    Always keep your legs warm, that blood also goes through your organs and can cause back aches if it gets too cold. I see people with all kinda jackets up top and just dungarees or Carharts down below and shake my head.
    Same with upper body, lightweight insulated layers over wool that you can add or take off to adjust comfort. If you see a good deal buy a slightly larger one to go over the right-size one. REI sells their own branded stuff cheaper, but sometimes the Patagonia or such is on sale, that's what the fishing guides who spend all day outside wear.
    Wind/rain shell with pit zips to regulate body temp when outside in wind and rain.
    Something warm on your head, beanie or balaclava. I like windproof here.
    Sirscrapntruckalot and D.Tibbitt Thank this.
  11. Oor
    Oor Road Train Member
    1,374
    3,538
    Jan 11, 2012
    If you're going to use that propane heater in a truck, buy a carbon monoxide detector.
