How do you remove wing window?
Discussion in 'Kenworth Forum' started by logtrucker25, Feb 7, 2013.
  1. logtrucker25
    logtrucker25 Light Load Member
    70
    9
    Jul 27, 2009
    northern CA
    I need to change the seal around the wing window on a t800. How do pop it out? Thanks
  3. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    trying to picture T800 wing window.... Does it have a rivet through the little swivel thing ? (sorry for my high-tech terminology) if so, I think you just have to drill out the rivet and then replace it (either with a new steel rivet or a bolt with two nuts) when you put it back together.
  4. logtrucker25
    70
    9
    Jul 27, 2009
    northern CA
    Hmm maybe. It has a post on the top and bottom the goes into to the frame around it. Maybe the posts are spring loaded an you pry one down? Thanks for the tip, I'll go look at it again
