How do you thump your tires?
Discussion in 'Experienced Truckers' Advice' started by A Bug, Jul 24, 2016.
  1. A Bug
    A Bug Heavy Load Member
    914
    1,851
    Mar 15, 2014
    Sevierville TN
    I cannot figure out how to find a low air tire by thumping it.
    I have two tires, 1 at 90 PSI and another at 105 PSI. They both make the same sound when wacking it with my hammer.
    What is the secret?
    TheDude1969 Thanks this.
  3. MidWest_MacDaddy
    11,209
    18,924
    Feb 21, 2015
    South Carolina
    Perfect Pitch... ;-)
    JReding and Mudguppy Thank this.
  4. MACK E-6
    49,175
    229,298
    If the difference is that small you won't notice it, but if a tire is flat you'll notice it right away. It will feel and sound spongy when you hit it.
  5. Dumdriver
    Dumdriver Road Train Member
    1,525
    2,138
    Jul 8, 2014
    East Coast
    You need a tire gauge to get exact PSI. The thumper is only to see if it's flat - or almost flat
  6. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    There is no secret, when thumping a tire you are only looking for a stiff recoil. That only means it has a majority of its air. Only a super trucker could determine a 90 vs 105psi tire... which would still require an inflation gauge.
    The point of thumping during a pre-trip is that as long as the tire is holding air, you can assume it is safe to drive. When this is done daily, you easily find a problem tire before it becomes a roadside emergency.
    BTW, good question A Bug!
  7. DustyRoad
    DustyRoad Road Train Member
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
    Thumping is good for finding a flat otherwise, trust only a air guage. Low pressure is really hard to determine using a stick or a baton.....obviously!
    pattyj Thanks this.
  8. MACK E-6
    49,175
    229,298
    ....Unless you have a good ear. ;)
    25(2)+2 and DustyRoad Thank this.
  9. A Bug
    914
    1,851
    Mar 15, 2014
    Sevierville TN
    Wish there was an easier way than using the guage with the temperature and all. I just remember at one time hearing a guy on these boards saying he could tell the difference of 5 PSI by thumping it.
    Thanks for the feedback.
  10. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    I'm gonna go off on a limb and say that tire thumping was the only way to check for pressure before the invention of a pressure gauge and before dot made strict guidance for tire pressure.
  11. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    You can't really tell that little of a difference. I used to do it more by how far the hammer bounces back rather than strictly by the sound.
