How does “random” drug testing work for O/O?
Discussion in 'Trucking Industry Regulations' started by Thetrashnoob, Dec 30, 2019.
  1. Thetrashnoob
    Thetrashnoob Light Load Member
    299
    57
    May 30, 2019
    I was reading up on the dot random drug testing and this is what I found
    DOT drug tests are required in the following situations:
    Pre-employment, or before you start your job responsibilities.
    Reasonable suspicion/cause, or if one or more trained supervisors reasonably believes/suspects that you are under the influence of drugs. This must be based on observations concerning appearance, behavior, speech, smell, etc.
    Random testing. Random tests must use a truly random selection process – each employee must have an equal chance to be selected and tested. These are completed quarterly.
    So if your a o/o how do these random drug tests work?
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    if i recall, an o/o has to join what is known as a "consortium" with other o/o's and the consortium admin/manager, contacts the o/o for the randoms.
    Rideandrepair and Cat sdp Thank this.
  4. Cat sdp
    Cat sdp . .
    21,180
    75,040
    Apr 8, 2012
    Orion's Belt
    Ya, the consortium is supposed to email the wife who then notifies me..... .
    It’s a joke......
  5. Dino soar
    Dino soar Road Train Member
    4,805
    26,922
    Dec 8, 2017
    How do you mean?
    Rideandrepair Thanks this.
  6. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    Was reading somewhere recently that because the percentage of doper drivers is now over 1%, there will be an increase in the number of randoms done....
  7. kemosabi49
    10,901
    47,288
    Jan 13, 2013
    SW Arkansas
    Yep. Back to 50%. Only went down to 25% for 3 or 4 years.
  8. Dino soar
    4,805
    26,922
    Dec 8, 2017
    Yes from 25% to 50%.
  9. Dino soar
    4,805
    26,922
    Dec 8, 2017
    I think if it goes back under 1% then they go back to 25%.
    D.Tibbitt Thanks this.
  10. Rideandrepair
    17,423
    56,526
    Aug 8, 2015
    O/O joins consortium, chooses a “DER”, who is responsible for contacting Driver, within so many days,supposed to contact Driver when near a DOT clinic, or near home terminal, or before Dispatching etc. Drivers got x amount of hrs to get test. Plenty of time to do it all. But don’t get too comfortable, I did and missed a random, and got a nasty gram, threatening to report Me to the DOT. Amazingly, haven’t been called since.
    clausland and Dino soar Thank this.
