How does Conway Truckload handle it?
Discussion in 'Con-Way' started by Polarbear25, Aug 21, 2014.
  1. Polarbear25
    Polarbear25 Light Load Member
    51
    38
    Jun 7, 2013
    Lost
    Hi there. I did my training and year of servitude with Swift so now I am looking around to see what's out there a little more in depth and I have a few question about Conway that I would be very greatful to have answers or opinions to that really arnt covered anywhere I can find so here goes:
    What do the delivery schedules look like? Do they give you enough time to do the runs comfortably or are you always on edge worrying if your going to mame it on time?
    Say you run into a bad accident and you know your going to be late, what are you suppose to do about in and what will the company do?
    For instance at swift I would just send in a running late macro with a new eta and what happened "bad accident ahead" and they would not think another thing of it and count you as on time with the new eta.
    How close do they work you to your clocks running out? Do they expect you to burn every last minute and no longer have time needed to find a rest area or some place to park?
    What do you guys usually average in miles per week? At swift solo i can only seam to average 1700 or so because soon many loads have me waiting around to pick up or wait to deliver or I sit undispatched for a few hours. The Conway recruiter said I could average about 2500-2800 a week. How accurate is that?
    How often do you actually go into NYC? or even Jeersy city? At swift I was always able to tell them I won't go to NYC but I know Conway is forced dispatch so if I get that run I know its just something I will have to get use to. The recruiter said only about 2% of all Conway's freight goes into the new York borrowz . how accurate is that?
    That is the extent of the questions I have right now so thank you very much for your time.
    yankeefan Thanks this.
  3. BrenYoda883
    BrenYoda883 Road Train Member
    1,248
    1,422
    Sep 18, 2013
    I dont know how conway itselfs handles their frieght load.. I am with Werner and we pull a lot of ConWay freight. . And the conway loads are always "Just in Time" loads.. meaning, you need to get there as soon as you safely can.. it is good frieight for those who like to run and get as many miles as they can..
    I like conway frieght cause there is always plenty of it... so you can get plenty of miles and earn a good check..
    However, I am a no non-Sense driver.. I dont shop or eat sit down meals when my 14 hour clock is ticking... I dont stop for fuel.. I fuel at the end of my driving day when I am shutting down for the night..
    Polarbear25 Thanks this.
  4. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Con-way truckload dispatches based on 45mph average speed & legal hours of service. The trucks go ~65mph so you'll usually have plenty of time.
    Call in & they will notify the customer & adjust your eta.
    45mph dispatch means they expect you to be able to drive 495 miles/day. Under ideal conditions you can do 700. I'm sure there will be the occasional load where stuff happened and you're now pressed for time, but those are the exceptions.
    Doable for weeks that you are on the road and not broken down. With breakdown & hometime, you should plan on 120,000/year & everything in excess is just a bonus...
    I never did, but if you live in the northeast you'd be more likely to go to NYC. It shouldn't be a common occurrence though.
    yankeefan and spectacle13 Thank this.
  5. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    As a conway truckload solo you won't pull much for con-way freight -- a shame because freight loads were so quick & easy...
  6. marmon96
    marmon96 Light Load Member
    98
    57
    Dec 27, 2013
    gardner,ma.
    what's everyone so worried about nyc for?one company i worked for would pay an extra 100 bucks to go and i would scoop up those loads as fast as i could.want some cheese with that whine truck driver?
    paul_4lp Thanks this.
  7. paul_4lp
    paul_4lp Road Train Member
    3,859
    2,371
    Oct 21, 2010
    Fort Myers, FL
    HE LIES!!!!
  8. paul_4lp
    3,859
    2,371
    Oct 21, 2010
    Fort Myers, FL
    Just Kidding ..... He speaks the truths !
    CargoWahgo and Polarbear25 Thank this.
  9. james evans
    james evans Bobtail Member
    Con-way loads are set at 47 MPH dispatch. Con-way Freight loads are set at 51 MPH Dispatch. Most weeks are good miles. Typically have plenty of time to make delivery. Forced dispatch yes. I been to NYC once in 2.5 years. We run Freightliner, Peterbilt, International, Kenworth, however, they are getting rid of International and Petes. The new K&W 680's are automatic so if your a new driver I see this as a disadvantage because you won't have experience shifting.
    Their policy is if you don't feel safe driving for whatever reason, pull over call dispatch and let them know when ur rolling again.
  10. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    I went thru NYC 500000000000000 times. Actually took an exit maybe 20 times.
    Mostly around the Queens and Chelsea area.
    Seen more us1 truck than I would prefer to see.
    I was in jersey city in the hurricane sandy aftermath after driving literally thru hurricane Isaac.
    Times are always manageable. I was always on the late board because I would go to sleep after I picked up and run nights.
    Had more running hours that way.
    Only fools run days with other fools.
    I like deer. They have more brains.
    So I guess you are more likely to go into NYC if you run nights if you put two and two together. But I'm giving dispatch more credit than they deserve.....trrrrruuuuussssttttt me....
    double yellow and paul_4lp Thank this.
