How does the DOT determine who gets pulled over for a weigh?
Discussion in 'Trucking Industry Regulations' started by BrandonCDLdriver, Sep 26, 2017.
  1. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    I'm confused and trying to figure it out. Is it totally random? I was told the DOT knows your weight before you cross the scales based on the weight on your BOL. I can't see that being true because one time I was pulling over 45K. I was just under 80K and got a green light on every scale. I saw a flat bed, obviously empty, get pulled into the same scale that green-lighted me pulling 45k lbs.
    Then later, on another run, pulling 2K lbs of packing foam, I get pulled into the scales.
    Most of the time our company gets green lights at scales no matter what we pull but it seems occasionally we don't. But it's seemingly at random times. Not based on weight.
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    I think they play rock, paper, scissors.
    WildTiger1990, Eowyn, mhyn and 5 others Thank this.
  4. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    I seen a "heat map scanner" (thermal camera?) used by RAWZE to detect hubs that are overheated "more" than the other axles.
    He said that heat map is a tell tale for mechanical issues (hub bearing). This alerts the officers to ask you to "come around the back" for a closer look a.k.a inspection
    heartlessangel7 Thanks this.
  5. dptrucker
    dptrucker Road Train Member
    4,695
    3,219
    May 14, 2012
    adelanto,ca.
    How does the d.o.t. know your weight on your b.o.l. if they dont invite you inside?
  6. KillingTime
    KillingTime Road Train Member
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    This needs to go to the lunch counter for some serious debate!
  7. nax
    1,999
    2,253
    Dec 14, 2016
    lunch counter?
  8. Brandt
    Brandt Road Train Member
    4,592
    6,305
    Sep 17, 2012
    If it just radom truck driving down the road they probably look at the tires tto see if the look low like they have a lot of weight on them. If your taking about in scale house, they have pre scales that can direct heavy truck to the scale and bypass the light weights. Then on the road they have Pre Pass and it weights the truck going down the road. Driver get a green or red light in cab to bypass scale or not.
    mhyn and Tb0n3 Thank this.
  9. KillingTime
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    That place where truckers gossip and dispel truths, half-truths, lies, and God-#### lies.
    driverdriver, 7-UP, Kyle G. and 2 others Thank this.
  10. Roberts450
    2,237
    3,638
    Feb 6, 2016
    Im thinking the OP thinks the DOT gets the info from the elog when he sends in his loaded call.
  11. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Table of infinite wisdom is another name for it
    I guess you haven't received your formal invitation yet..
    Can usually be found in truck stop restaurants...
    mhyn, BigBob410 and KillingTime Thank this.
