how far can I go
Discussion in 'Ask An Owner Operator' started by wickham455, Sep 26, 2014.
  1. wickham455
    wickham455 Bobtail Member
    8
    Sep 14, 2012
    I got an 07 columbia with a mercedes/detroit motor..its leaking oil from the o ring where the compresser meets the motor,every 20 minutes theres a puddle about the size of the bottom of a coffee can....my load leaves out monday morning and gets me back to the shop thursday.....shop dont have time till thursday...can I run it or will it get exteemely worse...
  3. marmonman
    marmonman Road Train Member
    1,417
    2,842
    Dec 14, 2009
    central illinois
    just check the oil more than once and add as needed
  4. bigdogpile
    bigdogpile Road Train Member
    1,931
    1,463
    May 16, 2010
    fontana ca
    Really ? your gonna run it like that ?"shop dont have time" I say you'll run out time before you make it to del point.
  5. wickham455
    8
    Sep 14, 2012
    marmonman....u dont figure that leak could get really extreme do ya?..I drove it about 500 miles like that to get it to our shop...they told me it's that o ring but wouldnt say rather its ok to drive it for a few days...I just dont know much about it...wouldnt want it to just all the sudden dump all the oil or somthin crazy
  6. marmonman
    1,417
    2,842
    Dec 14, 2009
    central illinois
    It won't blow out and drain your oil out it is just a leak not a stream you will be ok . Just keep a eye on the oil pressure and check it at least twice a day
  7. wickham455
    8
    Sep 14, 2012
    will do.. I appreciate it..just bought this truck 3 weeks ago and havnt made a dollar yet..spend spend spend
  8. jbatmick
    jbatmick Road Train Member
    2,198
    2,506
    Dec 1, 2009
    hastings, Fl
    I would run it, probably will not get worse if just an O - ring. Just keep an eye on the oil level. Keep 2 gallons in the truck, just in case.
  9. Jerry12
    Jerry12 Heavy Load Member
    723
    282
    Sep 9, 2014
    Leaking Oil, from the air compressor. Down stream from the air compressor, you'll find an increased buildup of oil inside the air dryer cartridge and the air tanks. You will want to start thinking about replacing your air dryer cartridge & drain "frequently" the air tanks. O-rings start to break down due to an increase in the buildup of sulphur trioxide compounds...due to running the oil in your motor too long in-between oil changes. Genuinely, im pretty sure your air compressor will continue to work but by all means check your oil level, replace as needed that is until you replace the air compressor.
    wickham455 Thanks this.
