How far will truck go before needing to refuel
Discussion in 'Questions From New Drivers' started by navywill, Jul 10, 2014.
  1. navywill
    navywill Light Load Member
    94
    40
    Jul 6, 2014
    I realize theres a lot of factors involved like speed, highway or not, model of truck etc... I was just wondering on average about how far will a truck go before it needs to be refueled?
  3. ScooterDawg
    ScooterDawg <strong>"The Blue Tick Lab"</strong>
    980
    654
    Nov 23, 2008
    Trinity, NC
    Probably the best wat to answer that is to say there is no definitive answer. One of the biggest issues at play here is the size of the fuel tanks. You can have thanks anywhere from 50 gallons up to 300 gallons or more. My experience has been that depending on the load and the engine you could get anywhere from 5 miles to the gallon up to 8 miles to the gallon. Now if you have 300 gallon tanks, that could mean anywhere from 1500 miles to 2400 miles. So the real answer is there is no average:. Sorry I couldn't be more help
    navywill Thanks this.
  4. navywill
    94
    40
    Jul 6, 2014
    Thanks a lot that gives me an idea!
  5. rwdfinch50
    rwdfinch50 Medium Load Member
    527
    595
    Nov 6, 2007
    Leesburg, Fl.
    I would think it will go until the tanks are empty lol. Sorry, couldn't resist. :sign5:
  6. Grumppy
    3,290
    11,792
    Dec 11, 2010
    West Monroe, La
    I am in a 2015 Cascadia with a DD15 & 10 speed, 2 - 120 Gal fuel tanks, about 6 MPG & I run about 800 miles & have about 1/4 (+/-) tank remaining.
  7. The Challenger
    The Challenger Kinghunter
    7,127
    3,374
    Dec 22, 2007
    East Central FL
    Most OTR fleets spec them out with dual 100-135 gallon tanks. I know Cowan and Prime give you only 100-125 gallons on their small sleepers. Not too sure about JB Hunt. I usually can tell by the number of straps holding the tanks up and diameter. Three and its most likely 120-150 gallon. Two and its most likely 50-125 gallon. Some macks and newer Volvos have four straps for their square shaped tanks. Freightliner has long and circular tanks on its class 8 while the city delivery trucks have square shaped fuel tanks with two-three straps. They usually hold anywhere from 25-75 gallons.
    bergy Thanks this.
  8. POINTDEXTER
    POINTDEXTER Light Load Member
    103
    46
    Mar 6, 2008
    Virginia Beach, Virginia
    trucks get in a normal range 6 -9 mpg. just do the math on the size of tanks. 2 one hundred gallons tanks at 7 mpg is approximately 1400 miles (it can vary). The biggest variables are weight of load, flat road or hills. Your speed will also be a factor, if you got a lead foot it will be less. If you use cruise and keep her steady mileage will be better.
  9. Badcable
    Badcable Medium Load Member
    356
    191
    Feb 1, 2008
    Outside Chicago, IL
    Idling and sitting in traffic will decrease the mileage a bit, not to mention a poorly maintained truck/fuel system will also lose some mileage than a properly maintained truck.
  10. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    If I'm scheduled to pick up a heavy load that will put me close to maximum weight I try to arrive to the shipper with 1/2 tanks or less. After scaling the load and balancing it then I calculate how many gallons I can add to the tanks and put in that many gallons, then look at the fuel gauge and understand that is the maximum I can fill at any fuel stop.
    Usually on these heavy loads I may end up getting up to maximum 3/4 tanks to avoid being overweight on the steers or drives. I did take a load last year where the maximum I could handle was 1/2 tanks, which meant I was fueling about every 400 miles.
    You never want to run your tanks dry. The last 1/8 fuel is generally not something I want going through my fuel filter. Usually I try to keep my tanks above 1/4.
  11. OldHasBeen
    OldHasBeen Road Train Member
    1,269
    924
    Dec 16, 2010
    I recall one one truck I drove back in the 70's had two one hundred gallon tanks & if the tanks were topped off I could make it half way to the west coast which was El Paso. If I did not top the tanks out at our yard myself I would stop & buy fuel before I got to El Paso. Of course we were not getting very good fuel mileage back them.
    Back in early 70's I drove a conventionalKW with one one hundred gallon tank, I could make a round trip to Greenville, Miss & back which is a bit over 200 miles. Plus I was pulling a cement tanker & we had exhaust turbine run by the engine to pressurize the tank for unloading. All the other trucks had to stop & buy at least 20 gallons of fuel to make that trip, the reason I didn't was mine would pull more fuel out of its tanks than the others. Many a time I made that trip when fueling up afterwards I would put about 97 to 99 gallons of fuel in my tank. Also I would always fill my tank right to the brim, a lot of our drivers would not take the time to do that so they could not go quite a far as I could.
    The only time I would stop & buy fuel on that trip was if I had a head wind coming or going & or it took me over 30 minutes to unload the cement. Usually unloaded in about 18 to 25 minutes if I was pulling my trailer.
