How fast does the NEXUS program get you across the border?
Discussion in 'Questions From New Drivers' started by Hilltop Hustler, Jul 20, 2023.
  1. Hilltop Hustler
    Hilltop Hustler Light Load Member
    78
    52
    Apr 29, 2023
    West Virginia, USA
    Occasionally I run upstate New York state to Detroit or the upper part of the mitten. The companyI'm with doesn't mind if we cut through Canada. We as drivers do mind because crossing the border can take forever.
  3. dunchues
    dunchues Medium Load Member
    554
    959
    Mar 23, 2012
    new brunswick
    Not worth it, you'd have all the ag of bonding the load into Canada then lifting it again at the US border which would cost money and take plenty of time too.
    Apparently it was common 30 years ago under different rules, and when the bridge collapsed in Nipigon a few years back there was a Thunder Bay to Sault ss or Detroit exemption for a few weeks while they repaired the bridge.
  4. Ridgeline
    22,423
    116,735
    You need to make sure your product and count are 100% accurate, and make sure that your waybill is 100% against the product and count. You have to make sure your insurance, passport, and all that are up to date.
    You need to fill out an A8B form (It is downloadable and printable), fill it out accurately, including your point of entry back into the US, you can't change your mind once it is filled out and accepted. Then you head to the border, have Canadian customs go through it, most likely inspect the trailer and truck, then stamp the form, and seal the trailer.
    When you get to US POE, then they will make sure the seal is intact, they will go through your paperwork, they will stamp it if they accept it, and let you go on your way.
    The last truck of mine that did this took an hour at the Canadian side and 20 minutes at the US POE - Detroit, but it was delivered right on Fort Street near the bridge in Detroit so it saved a lot of time.
    Not sure if you need to be bonded, that's questionable and you can call Canadian customs about it.
  5. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    870
    1,692
    Dec 15, 2021
    I cross at Coutts and Sweetgrass all the time,most of the freight is going to Alaska,so we use the In-transit paperwork ,and the ACE form going back into America.
    If you have the In Transit paperwork you have to stop at the Canada side on the way out and they will stamp the paperwork to release the bond.
    I only use a passcard crossing the border ,it's only a few minutes wait.
    But Coutts and Sweetgrass are probably not as busy as other crossings.
