How is it like sleeping in your truck?
Discussion in 'Questions From New Drivers' started by NewNashGuy, Aug 2, 2011.
  1. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    Hello, I couldn't find any answers about my particular question. When I searched I got a bunch of topics about comfortable beds to use. I was wondering how its like sleeping in a parked truck? Does it feel the same as sleeping in your car but you are laying down? Do other trucks wake you up, because those truck stops are loud so I assume ear plugs are necessary.
  3. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    Actually you would be surprised with the noise, usually when I'm in the sleeper I will not hear any other trucks unless a driver opens or closes a door right next to me. And also you have your engine, tv, computer, radio, etc also drowning out other noises.
  4. paul 1052
    paul 1052 Heavy Load Member
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    You've got a twin bed in the sleeper trucks, the noise just takes a little getting used to. It's nothing at all like sleeping in a car.
  5. roadkill4512
    roadkill4512 Medium Load Member
    396
    241
    May 9, 2008
    Lancaster,PA
    I slept really well in my truck.
    I invested in a tempurpedic foam mattress pad, pillow top mattress cover, quality sheets,comforter and down pillows.
    The key thing is to be choosy as to where you park. Avoid parking next to reefers or trucks that run loud APUs. I would try to find a spot between two quiet neighbors. In the event I had a noisy neighbor I would usually move to a different spot and if there were no other spots I'd resort to running a fan or idling my truck to drown out his noise.
    All in all I slept extremely well about 99% of the time. When I switched to local it took about a month until I slept as well at home as I did in my truck.
    Ranger70 Thanks this.
  6. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    It takes a little getting used to. Eventually you know the sounds that are your truck and what is in the next parking spot. White noise (fan radio etc) helps.
  7. MR. E
    MR. E Bobtail Member
    30
    5
    Jul 31, 2011
    San Diego, CA
    Driving solo, I got the best sleep.
    The soft massage with the engines idle.
    Ac blowing cold air.
    Music playing good ol country hits.
    But with teams, always slept with 1 eye open. Never got good rest.
    Worried I would go to sleep and wake up in a ditch or even worst.
  8. Dukefan8408
    Dukefan8408 Light Load Member
    65
    10
    Mar 16, 2009
    Amarillo, TX
    Biggest thing I couldnt stand is when you get a #### p.o.s truck beside you that releases air every 5 ##### seconds. Gets hella annoying, I cannot tell you how many times i've had to move my truck to get away from the noise. I always find the farthest corner away from the truck stop and just because I knew that the lazy truckers always go to the front first and that would be the last places to fill up if at all depending on what part of the country you're in. All in all its pretty decent sleep except for the occassional loud annoying truck.
    BigBadBill Thanks this.
  9. Grumman
    Grumman Light Load Member
    289
    120
    Nov 7, 2009
    Locust Grove, GA
    I've noticed freightliners are the ones building up air more often than not. Don't know why they do that. I think that spitter noise is much more annoying than a refer.
  10. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    You get to the point that the truck, reefer, APU sounds help put you to sleep. I hauled reefer containers for years. Want to talk about loud. The generator was at the back of the trailer but you could hear it from other side of lot.
    Just stay away from the bull haulers.
  11. jeeper
    jeeper Light Load Member
    89
    24
    Jan 3, 2011
    Dandridge, TN
    At first I had trouble sleeping well. Probably took only a few weeks or so and I started getting used to it. Depending on the truck it may insulated well enough to keep a good bit of the noise out.
