How is this a thing?
Discussion in 'Ask An Owner Operator' started by feldsforever, Oct 6, 2020.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
  3. feldsforever
    1,453
    1,440
    Nov 22, 2019
    On a different load with a different ticket it said almost 300 over
  4. Long FLD
    Long FLD Road Train Member
    11,927
    49,107
    Mar 4, 2015
    I bet dollars to donuts your proportioning valve thing for you dummy axle is messed up. You have too much air in the dummy axle and that’s throwing weight to your steer and causing you to have traction issues.
    Dale thompson and feldsforever Thank this.
  5. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Is there a way to test this?
  6. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
    Short wheel base
    feldsforever Thanks this.
  7. Long FLD
    11,927
    49,107
    Mar 4, 2015
    Split weigh your drive axles and find the weight on each axle.
  8. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    whats the problem. back up and ride away
  9. RockinChair
    RockinChair Road Train Member
    5,114
    12,931
    Feb 19, 2012
    CC, TX
    Slide that fifth wheel back a few notches.
    Casimir66, feldsforever and Dave_in_AZ Thank this.
  10. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Thats what I'm thinking. But its bolted in. So I'm gonna give it a go this weekend unless I need a tools
  11. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Yes
  12. Long FLD
    11,927
    49,107
    Mar 4, 2015
    I wouldn’t move your 5th wheel until you verify your rear suspension is working properly. You have a stationary 5th wheel, you’re not the original owner of the truck, and you’re having traction issues. So ask yourself if your traction issues and heavy steer are related to rear suspension problems or did this truck run around heavy on its steer axle for its entire life up until you bought it.
