How long can you dare without overhaul?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TallJoe, Oct 30, 2021.
  1. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    Assuming the engine works fine despite a high mileage....(1 350 000) No low oil pressure. No abnormal oil burning. Not loosing coolant.... catching my drift?
    Is there a threshold defined by mileage or maybe age...I know some people who decided to do overhaul, even though no catastrophic failure symptoms to happen soon were present. They spent over 20K at it and, ironically, after the overhaul some problems started. They were better off before it.
    What are your thoughts, do it as a preemptive measure or not touch it for as long as nothing shows really wrong?
    TheLoadOut Thanks this.
  3. Lazer
    Lazer Road Train Member
    1,825
    2,908
    Jan 22, 2017
    If it were me, ‘if it ain’t broke, don’t fix it’.
  4. Short Fuse EOD
    2,786
    8,738
    Jul 29, 2015
    Midwest
    What kind of engine what kind of oil? I don’t have any answers for you but I’m curious to see what others will say. Subscribed
  5. bzinger
    bzinger Road Train Member
    16,635
    66,092
    Dec 10, 2014
    omaha , ne
    I'd leave it alone if it isn't using alot of oil and oil pressure is good .
    Dino soar, TheLoadOut and TallJoe Thank this.
  6. Rideandrepair
    17,427
    56,532
    Aug 8, 2015
    Worst case scenario is to spin a rod bearing and have a rod go through the block. Rods and mains aren’t too expensive a job. Usually if oil pressures good. Bearings are good. Just watch the oil pressure. Chances are it will start mixing fluids first, or pushing coolant. Then it’s head home or to the Shop, ASAP!! A scheduled inframe will avoid that, and the worry till it happens. All depends on what you’re willing to risk. I ran mine right up till it almost quit. 3000 miles adding coolant, with a blown injector also. Thankfully, I made it home where I can get a fair price on an inframe. Last time I wasn’t so Lucky. Had to rent a Truck, pay tow bill, pay Dealership prices for an inframe, rent a car home, for 2 weeks. Cost was twice as much in 2008, as it was on my current Truck in 2020. This time I bought my Own parts, and had a Local Mechanic do the work. I only got what was necessary. I didn’t replace the rocker assembly, oil pump, or oil cooler. I may in the future. I think you can get a better built engine, by choosing the parts, and knowing the Mechanic. You have to look at it like any other maintenance. It’s inevitable. A basic inframe kit isn’t a whole lot of parts. Cylinder sleeves, rings, pistons , Bearings, oil pump check valve, and regulator. Seals and o rings. Add head(s) and injectors, maybe oil cooler, or a new oil pump, water pump, turbo, if wanted. Depending on their age. Dealer makes you change a lot of parts, to protect themselves from a warranty claim. Depending on length of warranty. I’ve heard of 1.5 mil, even 2.0 mil a few times. I personally would run it, rings are good, oil pressures good. But I take chances, many others don’t.
  7. TallJoe
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    Cummins ISX 2009 cm871 400 hp.
    It was supposed to be dead long time ago at 800 000 miles according to some. I' ve had it since 2014 bought with 550 000 on the odometer. I did not replace bearings. Nothing. Except for the camshaft that at 850 000 miles fell apart.
    Sometimes, I am getting paranoid, seeing this engine kind of like a 100 year old men...who. despite his joviality and clear mind, has his days accounted for.
    Sometimes, I drive and listen to how it sounds and the more I do it the more 'noises' I hear...or so I think.
    Frankly, I am itching to do it and get it over with and write it off while I can.
    Rideandrepair and TheLoadOut Thank this.
  8. DUNE-T
    DUNE-T Road Train Member
    7,014
    17,069
    May 10, 2015
    Detroit, MI
    My n14 made it to almost 1.75miles, just keep working it
  9. TallJoe
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    This is what I dread the most. Getting bogged down somewhere 800 miles away with a spun rod bearing.
    I was more than once advised to replace them but then again heard about as many voices agianst it.
    As far as coolant, I may add a quarter every now and then but there is no pattern or regularity... and it's been like that for as long as I have it. For a few months the level is intact and then I need to add some...that's impossible to tackle because there is no suspect and finding it would take more effort and money than it is worth it. I just learned to live with that.
    bzinger, Rideandrepair and TheLoadOut Thank this.
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,518
    6,578
    Aug 26, 2014
    Different trains of thought TallJoe: I will start with believing oil has improved a lot over the years because of better additive packages. Don't thank that crankshafts and bearings have changed much. Oil filtration is also much better.
    About 30 -40 years ago major company A changed rod and main bearings as preventative maintenance. That was done at about 350,000 miles and considered half life of a normal inframe. Later that grew to 1/3 life of an inframe as engines were running 900,000 to a million before inframe. They also ran the over head every 175,000 miles or so.
    Major company B just ran them as long as life was good. Used a bit longer oil change intervals. I never saw any of their engines run 800,000 miles before in frame.
    Now busting a million miles without having the oil pan off is no big deal.
    From the equipment point of view: If a machine will get the job done in a day at 1800 RPM the same as it will at 2000 RPM then why run it at 2000 RPM? Yes the crank rides on an oil film and is never supposed to touch the bearings anyway. However it is only going to make so many revolutions it its lifetime. The difference in 200 RPM for a 10 hour day is 120,000 revolutions.
    Will not stretch it out but bearings replacement maintains correct clearances and prolongs crankshaft life. From that same group of folks " Take care of the crank and the crank will take care of the bank" .
    As for age that is not a consideration. We rebuilt a tractor engine a couple years ago. Bearings were dated 1974 and it was running all those years.
    I kind of like the bearing change at estimated half life idea. You are so far into that I thank I would just run it.
  11. TheLoadOut
    TheLoadOut Road Train Member
    2,355
    11,192
    Nov 6, 2019
    I have 2 of the same engines, model and year, one 400hp turned up and the other 450hp. One has 940K the other has 1.1. Both have been solid other than some leaks that have been repaired.
    Rideandrepair and TallJoe Thank this.
