How long do you warm up your rig before driving.
Discussion in 'Experienced Truckers' Advice' started by LoneRanger, Mar 14, 2019.
  1. LoneRanger
    LoneRanger Road Train Member
    3,687
    9,584
    Jun 3, 2018
    i have a DD15 and want to know what’s the warm up period before driving it.
    I usually do 15 min but I guessing I need half and hour before I start driving.
    Anyone know?
    And I have read on here normal oil pressure is around 13-15 is it correct?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Oil at 30+ PSI, Engine stable at 1200 (First 5 minutes dead idle for turbo protecting and feeding) airride up and inflated all around, particularly the trailer. Water temperature 185 to 200. Oil temperature up to 160 and stable Pyrometer running 700 or so. Restriction less than 7, ideally 3.
    The truck will have arthritis for about 10 miles, no jacobs braking until axles and transmission oil agrees with engine oil more or less.
    This is my personal framework, not necessarily for your particular engine.
  4. Allow Me.
    10,724
    12,418
    May 28, 2009
    Rancho Mirage, Ca.
    I start out slow and ease up to speed. Idle out of the truck stop, gently proceed down the frontage rd, left turn onto the highway on ramp and then get on it.
  5. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
    I warm it up all night long. Idk my mpg isnt that greatest tho.
    Smut, D.Tibbitt, Woodys and 4 others Thank this.
  6. Bean Jr.
    Bean Jr. Road Train Member
    5,539
    9,877
    Mar 30, 2014
    Please ignore that guy. And I don't mean @Allow Me nor @Snakeschasingcars . Basically there is no reason to warm up any vehicle that much. Start your engine, do your pti, then go. Drive easy until your coolant temperature gets off the peg. Any more than that is a waste of fuel.
  7. 25(2)+2
    18,756
    45,797
    Sep 18, 2006
    the road less travelled
    They say lots of things, but that engine isn't real quick to warm up idling. It depends on outside temp, when it was last run, whether it's plugged in, etc.
    When the temp guage starts to move it's OK to start moving from my experience, and once it starts working a little, the warming up is faster.
    flood, laaylor, Truckermania and 4 others Thank this.
  8. Jwhis
    Jwhis Heavy Load Member
    862
    1,356
    Jan 17, 2018
    Modern vehicles don’t require warming up as much as the olden days. Oil technology has come a long way
    KB3MMX, laaylor, roshea and 3 others Thank this.
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Start it do your pre trip/paper work and go. The newer engines warm up pretty quick
    KB3MMX, Tb0n3, laaylor and 3 others Thank this.
  10. Gumper
    Gumper Road Train Member
    1,579
    3,845
    Jan 7, 2018
    Butte, MT
    As soon as the air pressure is up I’m ready to roll during the warmer months. I’ll give it 5 minutes when it’s below 20*.
    Tb0n3, laaylor and Bean Jr. Thank this.
  11. Hammer166
    7,553
    27,498
    Aug 18, 2007
    ~8600+' and loving it!
    I usually only warm until the oil pressure starts to drop from peak. I have a Data Star, so I can see when oil temp comes up off the bottom of the sensor (74 deg.) and that's normally where the pressure starts to drop to normal levels. Then just take it easy until you've got water temp up.
    If I'm parked somewhere that's going to require heavy throttle due to geography, I'll let it warm a bit more so I can have more than 150 degrees of water temp before I need to mash on it.
    Dino soar, KB3MMX, Tb0n3 and 3 others Thank this.
