How long do your wheel seals last??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Scrapper, Feb 1, 2012.
  1. Scrapper
    Scrapper Light Load Member
    289
    83
    Jan 19, 2010
    Nashville, AR
    Just wondering what you guys see. Steer or trailer. How long do your wheel seals last? What types are you running? Do any of you have little tricks of the trade to make them last longer? Just for information purposes. I have heard many different ways of making them last longer. Even saw a mech use red silicone on them. We haul poles so we are in a rougher enviroment than many. We use stemco seals and lucas hub oil. But just seeing what your experiences are. Seems we always have one or two a week on ours. Mainly trailers. Thanks.
  3. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Stemco gritguard seals and 85-140 oil in the hub, very few failures.
  4. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    I agree on the stemco seals, the grit guards, we used 50W in some and 75/85 in others. The old style leather seals lasted the longest, when I worked in Edmonton especially on trucks running north. Also if you let the oil run low they are done, Never seen a seal leak from being over full.
    I know of guys that would pull the plug on the cover and drain out the oil about 1/2 the total and clean the magnet and refill. They did that every second oil change.
    They had trucks that were very well maintained and made money, any amount of metal fillings on the plug and the wheel came off and the bearings were changed. A little metal and the plug was checked next oil change. Every thing done was written in a book that stayed with the truck.
  5. papa1953
    papa1953 Light Load Member
    71
    139
    Aug 13, 2009
    Nebraska
    Be sure and keep the breather vents clean and able to breath on drives, so the pressure from heat can escape and prevent blowing out the seals.
    heavyhaulerss Thanks this.
  6. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Im curious to see if there is a magic cure on this as well. I got one axle that eats seals, and im afraid im due for a new stub pretty quick!
  7. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Always verify correct bearing numbers and proper fit to the axle when having repeat unexplainable seal failures. I inherited one where a guy mistakenly installed a wrong inner cone bearing that didn't fit the axle properly (loose fit) although it was the mate for the bearing cup (race) for a different axle application. Three seal failures later, I was appointed to hunt it down. Incorrect inner bearings had been installed on both sides of one drive axle.
  8. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    I have very few problems with the seals on my trailers, but it seems like I have more seals on the tractor drives go bad than I should. The guy that replaces the for me uses stemco seals and knows how to install them correctly.
  9. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    Stemco and Lucas are a great combination. I change out the oil twice a year and almost never have hub seal problems. Takes about 90 minutes to change the hub oil and it's good insurance.
  10. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    This is why I always spin the wheels and hit the tire with a sledge hammer as its going around and I hit hit top, bottom and sides.
    WOW I'm still running on the same oil in my trailer hubs and its been 5 years!
    My brother tried some Lucas stuff, think it was red, and it burnt his seal up in less than 400 miles. We are still scratching our heads on that one!
  11. Starline
    Starline Medium Load Member
    357
    251
    Jun 1, 2011
    Middle Tn
    I hate to say anything for fear of jinxing myself, but in 12 yrs & 836K miles I've only replace 1 drive seal and the left front seal twice, right front seal once.
    My trailer on the other hand, needed new seals every 2-3 yrs until I converted to grease packed bearings.
