How long should a custom built CB radio last?
Discussion in 'CB Radio Forum' started by blacklabel, Dec 1, 2011.
  1. blacklabel
    blacklabel Heavy Load Member
    870
    1,268
    Nov 6, 2011
    MO
    Custom built cb longevity?
    How long should one last? Like the 29s swing 80-90 watts?
    Thanks
  3. am89
    am89 Light Load Member
    101
    12
    Aug 1, 2010
    METRO NYC
    Was this question in American English!?
  4. Rat
    Rat Road Train Member
    I have yet to see a 29 swing more then 40 ish watts without an RFX 75 bolted to the back of it. But then the RFX 75 puts them in the 100 ish range for swing.
    So if it has an RFX and is swinging 80-90 then it is not being pushed too hard and should last a good while. If it doesn't have an RFX strapped to it then I don't see it last very long at all, if it is actually swinging 80-90.
  5. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    If you mean how long a radio should last a well built rado should last 10 years or more ......
    AT 20 years the caps will go bad .......
    AT 30 years the old style cabon resisters are shot ......
    AMPS are the same I have amps that are 30+ years old and HEAT is the killer on a amp .....keep them cool and they will work for decades ....
    MOST that die are because everyone wants 100 watts out of a 100 watt amp .... hold it down to 50 and it will out last the owner ....
    Here is a 50 year old transmiter only some caps had to be changed ....
  6. OutLawRadio
    OutLawRadio Light Load Member
    140
    13
    Nov 28, 2011
    Texas
    RFX mod only do a honest 80-85 watts
    Most only last a year or so if run regularly
    near peak.
  7. blacklabel
    870
    1,268
    Nov 6, 2011
    MO
    Well I was lookat at one with the rfx on the back from custombuiltcbs.com just didn't want to spend my money and it die in 6 months
  8. IDIeselman
    IDIeselman Light Load Member
    173
    59
    Feb 23, 2011
    Ludington on the Lake
    Won't happen. I ran Dougs http://customcbradios.com/Cobra-Black-Chrome-Stealth-Radio-RFX-Version-P643685.aspx black chrome stealth hard, long and often for over two years while transfering it in and out of a loader everyday. If you meant to type customcbradios You can feel comfortable you are buying a good radio that will last.
  9. blacklabel
    870
    1,268
    Nov 6, 2011
    MO
    Thx that's what I meant. Thanks you for the replies. I believe wwhen im y doug will get my money.
  10. OutLawRadio
    140
    13
    Nov 28, 2011
    Texas
    I have one from Doug and one from
    Al,Doug's popped at 14 months and Al's
    just short of 18 months. Neither was used as a driver.
    Take it FWIW
