How long to let truck shut off with laptop
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by CHICKENMAN, Apr 29, 2009.
  1. CHICKENMAN
    CHICKENMAN Light Load Member
    176
    60
    Oct 28, 2006
    Winston Salem NC
    I'm trying to save fuel by not idleing the truck alla the time while I'm living in here. I have a Toushba Qosmio laptop and a 400W inverter. How long could i leave the truck off before it wont start??? I have a 06 volvo with 6 battyies, Sorry for asking a dumb ???
  3. dirtyoldman
    dirtyoldman Light Load Member
    264
    70
    Dec 30, 2007
    None of your business
    I had a 3 battery volvo and it was a while, most I have done was 5hrs. In my car with a small diehard, I have run it for 4_ hrs also.
    If it has ICON or the VOLVO idle system, you can set it to start when batteries low.
    Also if you run a reefer, you can use the reefer to charge the truck with a set of 20ft cables.
    K
  4. Pawnd
    Pawnd Medium Load Member
    346
    143
    Apr 8, 2009
    Chasing wind
    The technical answer would be look at your laptop spec and see the draw is. Check amp hour rating of the batteries divide by 2 and do a little figuring.
    Typical draw is 90 to 100 watts for a laptop ac adapter. Watts divided by volts = amps (approximately). So roughly 8 amp draw. 1 250 amp hour battery divided by 2 for safety, so 125 divided by 8 = 15.6 hours. This is to reach 50% discharge. With 6 batteries 93.75 hours. This assumes no other loads; fully charged batteries in good shape and reasonable temperature. Lead acid battery discharge capacity is affected by temp. But is likely way longer than you will likely sit.
    Wiseguywireless Thanks this.
  5. Wiseguywireless
    Wiseguywireless Road Train Member
    1,693
    801
    Dec 21, 2007
    Petoskey, MI
    Once my bat gets to a certain level, everything shuts off so I still have enough charge to start it. I have left mine on all weekend and still was able to start it.
  6. CHICKENMAN
    176
    60
    Oct 28, 2006
    Winston Salem NC
    thanks for all the imfo guys :) I Love this truckers forum. U guys are the BEST:biggrin_2559:
    So are u saying i can leave it shut down for 93 hr's DANGITTTTTT
    thanks again
    And Pawnd u dont need to be a truck driver, u need to be a engineer :D
  7. Pawnd
    346
    143
    Apr 8, 2009
    Chasing wind
    I majored in biochem, you just have to have a piled high and deep (phD) to do what I wanted.
    CHICKENMAN Thanks this.
  8. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Your inverter will scream at you (low input level) before the truck batts go out.
    Type away, a quick 5 minute idle every 4 hours is what I do. Should be good to post!
  9. CHICKENMAN
    176
    60
    Oct 28, 2006
    Winston Salem NC
    OH NO thats what my late wife used to do alot, scream at me alot hehe
